Author Topic: buying a tri-sync monitor vs. using one already in a cab.  (Read 2302 times)
scurvy
  • Last login:July 23, 2008, 11:31:43 pm
« on: April 09, 2007, 06:22:05 pm »
i'm debating whether to buy a cab with a monitor already in it or buy a seperate monitor.  For example, say i bought a mortal kombat 2 machine to convert into a mame machine, is this a "try sync" monitor? will i be able to use and view a front end with it? also is it a major pain in the ass to hook up a vga card to it? i read the FAQ and it seems a bit confusing but i could be wrong.  :dunno
any help appreciated
tetsu96
  • Last login:September 06, 2024, 12:00:03 pm
  • MAME On...
    • My Old Cabinet / MAME32 build site
Re: buying a tri-sync monitor vs. using one already in a cab.
« Reply #1 on: April 09, 2007, 07:37:30 pm »
Mortal Kombat II uses a standard resolution monitor.  You're not going to hook a PC up to that unless you use an AVGA or something similar.
Tri Syncs are good, but if you're just starting out, you may want to use a TV just because it's easier / less work.  As you get to be more of a purist you should start looking into things like arcade monitors / etc.
scurvy
« Reply #2 on: April 09, 2007, 07:39:39 pm »
well i am planning on using AVGA.. so would it be a problem? could i buy any old cabinet with a working monitor and hook my pc up to it for mame?
i guess what i'm asking is, are the popular monitors people buy from WG and betson the same as the monitors in most cabs?
« Last Edit: April 09, 2007, 07:42:05 pm by scurvy »
ahofle
    • Arcade Ambience Project
« Reply #3 on: April 10, 2007, 12:57:52 pm »
The vast majority of arcade games just have a standard res CGA monitor in them.  A 'tri-sync' can output standard CGA res, medium res, and VGA res and so is different than a standard arcade monitor.
And yes, you can hook the arcadeVGA to a regular standard res arcade monitor.
scurvy
« Reply #4 on: April 11, 2007, 01:34:26 am »
so would i be able to view windows and a front end of a emulator if i hooked  a pc up to a standard monitor thats in a cab with AVGA, or would i have to tell you what monitor it is.
ahofle
« Reply #5 on: April 11, 2007, 10:43:42 am »
Yeah any standard res arcade monitor can run at 640x480 interlaced with an arcadeVGA for windows or your frontend.  Windows will flicker a bit due to the interlacing but it's nothing major.  Games and frontends look great at that resolution.
