Author Topic: which button should I use for start and which for coin  (Read 1837 times)
struby
  • Last login:April 23, 2007, 08:42:05 pm
« on: April 04, 2007, 11:53:38 pm »
so i have a button with a guy on it like a regular arcade machine, the little black guy, and a button with an arrow, well it's more of a sideways black triangle, which do you think would be more logical as coin and which as start, is the guy typically start on most arcade machines?
bfauska
Re: which button should I use for start and which for coin
« Reply #1 on: April 05, 2007, 12:08:46 am »
Stick figures = start.
struby
« Reply #2 on: April 05, 2007, 12:44:35 am »
good thanks much
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: April 05, 2007, 08:22:48 am »
Agreed.  I used a green button next to start for coin inputs - "green = color of money".  Made sense to me, but probably only to me.
Kaytrim
  • I'm too nice a guy
« Reply #4 on: April 05, 2007, 11:37:21 am »
One project had GOLD buttons for the coin.  It was metallic paint but still GOLD. :o :laugh2:
ahofle
    • Arcade Ambience Project
« Reply #5 on: April 05, 2007, 11:44:08 am »
MikeDuece makes little vinyl '25¢' decals that you can use for coin buttons.  I think they are on his back burner at the moment though.  Check this thread:
http://forum.arcadecontrols.com/index.php?topic=49291.0
« Last Edit: April 05, 2007, 11:46:04 am by ahofle »
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: April 05, 2007, 01:06:37 pm »
Good idea, I forgot about them.
Another is RandyT's NovaGem CDR's or wiring to the coin return switches, if either of those would be options for you.
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #7 on: April 05, 2007, 01:15:10 pm »
I use yellow  :) one in mine.
« Reply #8 on: April 05, 2007, 01:39:46 pm »
Try this one:
