Author Topic: Isolation transformer  (Read 2230 times)
rfr341
  • Last login:May 24, 2017, 12:15:31 am
« on: March 30, 2007, 11:25:23 pm »
Hi, I have a nanao/sega 14" mc1400s monitor and need to get an isolation transformer for it. Would a standard 120 volt transformer work with it since I believe the monitor uses a 100 volts to work. If I am wrong on the monitor voltage please correct me. Also what should the minimum amps of the tranformer be. Thanks
Kevin Mullins
    • Me on Myspace
Re: Isolation transformer
« Reply #1 on: March 30, 2007, 11:34:12 pm »
Do NOT use a standard 120 volt isolation transformer !!
It will damage the chassis almost instantly.
You will need a stepdown isolation transformer to go from 120 down to 100.
segasonicfan
  • Last login:April 12, 2020, 02:34:26 am
« Reply #2 on: April 06, 2007, 04:28:37 pm »
Hrmm...interesting.  Would the same go for Nanao monitors?  I have one that clearly shows 100v marked on the back of the tube...
-Segasonicfan
Ken Layton
  • Guru
  • Technician
« Reply #3 on: April 06, 2007, 05:38:41 pm »
Yes, Nanao made monitors for Sega. Most Nanao and Nanao/Sega monitors operate on 100 volts AC and are usually marked "100 VOLTS".
rfr341
« Reply #4 on: April 06, 2007, 06:22:30 pm »
Ken do you happen to know where I could get a 100volt transformer for my monitor? Would a nintendo isolation transformer work with  a nanao chassis since it is 100 volts?
« Last Edit: April 06, 2007, 06:26:05 pm by rfr341 »
segasonicfan
« Reply #5 on: April 06, 2007, 07:25:08 pm »
Found the transformers:
http://www.smelectronics.com/japantrans.htm
It's a 100w step down but my Nanao is rated at 105w :/  That is maximum rating though so I think I may just take my chances...
-Segasonicfan
« Last Edit: April 08, 2007, 01:44:53 pm by segasonicfan »
MikeStl
  • Last login:April 14, 2007, 07:12:25 pm
« Reply #6 on: April 12, 2007, 03:39:51 am »
-Segasonicfan
I wouldn't reccomend pushing it that close.  You really should look for an isolation transformer that has a 100v tap in it.  I found one listed here: http://quarterarcade.com/Game.aspx/4526?m=1
