Author Topic: SONY PVM-2530 Does this monitor display Arcade RGB  (Read 2151 times)
albert_c
  • Last login:April 06, 2010, 03:57:07 pm
« on: November 21, 2006, 02:54:47 pm »
I'm about to score this monitor locally.  It has RGB, but can anyone tell me for sure if it's the same 15hz RGBHVG like an arcade monitor?  Will a standard arcade board running at low res work with this monitor?
http://www.broadcaststore.com/store/model_detail.cfm?id=5062
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:18:33 am
Re: SONY PVM-2530 Does this monitor display Arcade RGB
« Reply #1 on: November 22, 2006, 12:05:05 am »
This monitor are used for like Advertising such as the ones in a 7-11 stores (as I'm told). I have one but forgot the namebrand and mine is a 21". This suzkerz are so heavy. This are really commercial made and built like a tank IMO.
So anyway, it does 15khz (well mine did) using the RGB connections on the back. I tried some veritcal classics like the PAC family, Dkong Family etc... Looks nice...
I'm told that this monitors are/were expensive. I have done a little research on the brand I have and it did cost lots of $$$$$....
Its to bad your in the Jose section. I could probably sell you mine for $100.00 but then the shipping will KILL YOU on the spot :) Well, I really dunno but this beast are very heavy. Good luck
Free VGA Breakout Cable
albert_c
« Reply #2 on: November 22, 2006, 02:26:42 pm »
Thanks, It probably does display CGA.  Only one way to find out.
