Author Topic: strange computer problem...  (Read 1203 times)
SNAAKE
  • Trade Count: (+29)
« on: May 06, 2006, 08:52:42 pm »
my dvd burner doesnt show up in windows anymore. I checked from setup(blue screen) its there but windows cant detect it. Tried burning a dvd it says I only have the image recorder. anything I can do here ?? thanks in advance.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re: strange computer problem...
« Reply #1 on: May 06, 2006, 09:24:28 pm »
Drive Died
IDE channel going bad
Cable came unhooked
Driver mysteriously vanished from windows
AtomSmasher
    • Atomic-Train
« Reply #2 on: May 06, 2006, 09:31:51 pm »
I assume this means bios, which shoud mean the drive is connected properly.  First thing I'd do is go to device manager and make sure there were no exclamation points or question marks (which would mean a driver problem).  You can get to the device manager by right clicking on my computer, go to properties, click on the hardware tab, then click on device manager.
If the device manager showed no errors, then I'd try checking the computer management program.  You get to it by going to the control panel (through the start menu), then administation tools, then computer managment.  Go down the list to disk management and make sure the dvd drive is there and that it is assigned a letter, if its not assigned a letter you won't be able to use it.
If neither of those fix anything then its probably a bad drive.
SNAAKE
« Reply #3 on: May 06, 2006, 10:48:31 pm »
had to reinstall driver fro the IDE chanel from device manager. I did check there before but it said "this device is working". whatever problem fixed thanks !! :cheers:
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 11:11:43 am
« Reply #4 on: May 07, 2006, 10:44:51 am »
I had a friend that had a laptop that the cd/dvd no longer shows up but it did boot from cold start. Her laptop was a mess, no sound, virus encountered, Explorer no longer work, Nero did not work, so As limewire etc....So i just recommended a good clean up and booted from the CD/DVD drive and reformat and re-installed everything. Works like a charm now :).
Free VGA Breakout Cable
