Author Topic: MAME - I need ESC and TAB buttons assigned on my PSX controllers  (Read 1889 times)
eastbayarb
  • Last login:March 08, 2013, 12:15:06 pm
Yo,
I just wired up some cheap PSX controllers to some Happs buttons/8-way joysticks and put them in my control panel (with the appropriate adaptors I have, I can use these controllers/control panel with PC, XBOX, Gamecube, PS2, and Dreamcast). This is a 2 player panel. Buttons X, O, Square, Triangle, L1, and R1 are mapped to buttons 1-6 in MAME, Select (located under the 6 main buttons) is Coin, Start is Start (duh), and L2 and R2 I want as admin buttons (Player 1 L2/R2 and Player 2 L2/R2 make for a total of 4 admin buttons).
I want as admin buttons TAB, ESC, Pause, and Enter. Mapping Pause and Enter is no sweat, but how would I map TAB and ESC to my buttons? Is there some way (.ini file or otherwise) to use alternatives to TAB and ESC that perform the same function?
I know similar posts have been asked about this (believe me, I did do a thorough search on this site and on Google), but they involve IPAC and keyboard which I don't wanna use since I'd like to be able to control everything with my control panel and PSX pads.
Thanx!
« Last Edit: April 23, 2006, 06:58:31 am by eastbayarb »
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 10:43:21 am
Re: MAME - I need ESC and TAB buttons assigned on my PSX controllers
« Reply #1 on: April 23, 2006, 01:54:10 pm »
just hit TAB, push ENTER on CONFIG MENU (TAB) and push the button you want and do the same thing for UI_CANCEL (ESC) and hit the button you wnat assign to it, all this are under the INPUT GENERAL/User interface settting section.
« Last Edit: April 23, 2006, 01:56:03 pm by Thenasty »
Free VGA Breakout Cable
eastbayarb
« Reply #2 on: April 23, 2006, 03:59:21 pm »
Thanx for the info!
How about the TAB key?
liquid8
  • Last login:January 08, 2026, 02:01:16 pm
  • I working on it.. it'll be a while.
« Reply #3 on: April 23, 2006, 10:35:56 pm »
Sounds like you configuring directly in mame, but for those that haven't, and just use an adaptor, there is a program called Joy2Key which will convert joystick button presses to keycodes:
http://www.electracode.com/4/joy2key/JoyToKey%20English%20Version.htm
Useful when the frontend isn't joystick friendly.
liquid8
eastbayarb
« Reply #4 on: April 24, 2006, 12:29:26 am »
Thanks for the suggestion on joy2key and while I have considered it before, I would much rather be able to assign buttons within emulators.
Now is there any way to have the TAB button reassignable to some other button?
Thenasty
« Reply #5 on: April 24, 2006, 04:13:43 pm »
i already mentioned it above. When you are in General/user interface, select the one that says CONFIG MENU (default is assign to TAB)., hit enter and assign to WHATEVER YOU WANT.
