Author Topic: Methods for extending a knob to outside of Control Panel???  (Read 2554 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: December 04, 2005, 10:13:07 pm »
I have a multi switch box in my control panel that has a knob on it that allows me to switch between systems ps2,dc,pc.How can i extend the knob so it can reach the outside of my control panel side. I mean how do i extend the length of the knob shaft? what product or method could i use. I already know about buying different knobs but they dont make long enough ones. Thanks for any advice....
Necro
  • Last login:December 31, 2025, 03:36:17 pm
Re: Methods for extending a knob to outside of Control Panel???
« Reply #1 on: December 04, 2005, 10:27:00 pm »
There's prob. an easier way, but first thing that came into my head was get a metal rod, similar diameter to the one in the switching box you have now, cut an X groove into the metal of the switch/knob, and carve out a similar shape into the metal rod you purchased.  (could even do a solo groove, but it would have to be secured better to prevent slipping).
Then just put the knob on the top of that extended piece.  Would require that carved out too (would be detailed dremel work).
Just first thing that popped into my head.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: December 04, 2005, 11:24:20 pm »
Some volume control (potentiometer) manufacturers make "shaft extenders".
quarterback
« Reply #3 on: December 05, 2005, 01:18:29 am »
OscarControls used "shaft collars" to extend his volume knob
See here for more info: http://www.oscarcontrols.com/volume/
And here's a pic: http://www.oscarcontrols.com/volume/09.jpg
-- Chad Tower
dennis808
  • Last login:May 13, 2021, 08:40:00 am
  • Holy Sanwa-sticks!
« Reply #4 on: December 05, 2005, 05:27:17 am »
Here's another one:
Could you post some pics of your creation? I'm very curious since I'm also finishing a cab with a DC, PS2 and PC in it.
"Complexity is the process by which the obvious is obscured by the irrelevant." -HSW
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #5 on: December 05, 2005, 06:33:09 am »
Barring none of the above works, maybe you could solder two/three more wires to where the knob is currently soldered and add a second knob to the cab (i.e., extending by using wires).
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
Bones
  • [Moderator]
« Reply #6 on: December 05, 2005, 06:46:09 am »
If you know somebody with a metal lathe turning something like this up would be dead simple. At the worst I can imagine even a general machine shop would only charge a few bucks to have it done.
danny_galaga
  • Last login:Yesterday at 03:43:22 pm
    • dans cocktail lounge
« Reply #7 on: December 05, 2005, 07:15:34 am »
that all looks so 'bought'! i used a bit of k & s aluminium tubing to extend mine. on the other end i glued a bit of whittled down dowel to fit the knob on...
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #8 on: December 05, 2005, 07:57:01 am »
If someone has a direct link to one of those shaft extenders pictured, PLEASE POST IT.  I have been looking for one for months.
BTW, do a Google Search for SHAFT EXTENDER and see what happens.  There are 41,000 hits that all think I want a larger unit (if you know what I mean).
quarterback
« Reply #9 on: December 05, 2005, 11:14:56 am »
Search for 'shaft collars' or "Shaft Coupling".   You'll easily find what you need.
Here's one place: http://www.surplussales.com/ShaftHardware/ShaftH-8.html
-- Chad Tower
Negativecreep0
« Reply #10 on: December 05, 2005, 11:35:02 am »
YES!!!!!!!!!!! all the places i found are machine shops and they are like minimum 100 pieces per order
thanks i love you like a fat kid loves cake
Ed_McCarron
« Reply #11 on: December 05, 2005, 01:36:42 pm »
Just don't do it at work.
« Reply #12 on: December 05, 2005, 01:39:52 pm »
I find that if you get someone to rub the knob just right, it will extend itself.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 07:45:11 pm
« Reply #13 on: December 05, 2005, 03:59:15 pm »
yea, but is it long enough
Free VGA Breakout Cable
« Reply #14 on: December 05, 2005, 04:05:39 pm »
It's long enough for you, old man.  It's the knob that did the Kessel Run in under 12 inches.
danny_galaga
« Reply #15 on: December 06, 2005, 04:08:47 am »
« Reply #17 on: December 06, 2005, 02:35:27 pm »
It's like the adult PPV listings on DirecTV.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #18 on: December 07, 2005, 05:57:57 am »
I find the knob never needs extending, he's always outside the control panel, waiting for me to whup his ass again with my awesome bo staff skillz
