Author Topic: mng to avi converter  (Read 8231 times)
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« on: October 11, 2005, 07:36:55 am »
I don't know if you guys knew already but I've tried it and it works like a charm. Now it's easy to create
Re: mng to avi converter
« Reply #1 on: October 11, 2005, 08:05:27 am »
Buddabing's 'movie maker' combines a series of PNG's with WAV samples to get both video & sound.
Buddabing
« Reply #2 on: October 11, 2005, 08:17:31 am »
Please read the wiki!
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #3 on: October 11, 2005, 07:44:36 pm »
I tried that MNG construction set at work over 6 months ago and it totally died on the mng's I had at the time - couldn't even display more than the 1st frame of the MNG let alone convert it. Sounds like its imrpoved a lot.
mvgt_7
  • Last login:October 26, 2005, 06:56:29 pm
« Reply #4 on: October 11, 2005, 08:07:47 pm »
That sounds pretty good, but my mng2avi utility is free, and will mix in sound.
how do you use this tool, mng2avi cus i try'it and it was confusing, i got like 3gb of mng's with mp3 sound and would like to make them avi's to use with amewah... thanks for any info
Buddabing
« Reply #5 on: October 11, 2005, 08:18:49 pm »
The utility is designed to convert mngs generated by the user within MAME into AVIs.
It will also work with generic mngs, just add movieloops 0 to the mng2avi.ini.
The utility is designed to use wav files rather than MP3s. But it might work with mp3s. Try it, just launch a command prompt, navigate to where mng2avi is, and type mng2avi and press enter for instructions.
Silver
    • Mods'n'Mods
« Reply #6 on: October 11, 2005, 10:09:18 pm »
Taking a stab in the dark, but I'm guessing you might have crashtests mng pack that was released a while back, which had lots of very short mng's with mp3s.
If Buddabings tool does not work with mp3's, you could try my old one:
http://www.silverfoxy.plus.com/MNG2AVI.html
Its a complete bodge, a requires about 3 other programs (detailed on the webpage), and I've had reports that it does not seem to work at all with mames mng output. However, I wrote it using the crashtest pack as my sole source of mngs, and it successfully converted the whole lot to avi's, so feel free to give it a try.
To be completely honest you will get superior videos - both in terms of quality and of what you have a video of - by using Buddabings Movie Maker and making your own avi's (A lot of the crashtest ones don't have any gameplay etc...) Although this tends to take a bit of time to set up.
mvgt_7
« Reply #7 on: October 12, 2005, 12:56:39 am »
THANKS ALOT FOR THE INFO.....ILL TRY THE TOOLS AND LET U GUYS KNOW... THANKS
PedroSilva
  • Grettings !
« Reply #8 on: October 12, 2005, 11:00:56 am »
Just in case anyone is interested ... here's a freeware tool that captures video an sound to an avi from full screen, window or region ...
It needs a fast machine ...
