Author Topic: Configuring MAME to use a spinner...  (Read 1447 times)
Sinner
  • Last login:September 17, 2024, 11:27:45 am
  • Half the lies they tell about me, aren't true...
    • Geek My Gadget
« on: September 23, 2005, 09:56:24 am »
Is there a special version of MAME needed to set up a spinner??
Here are my options...I have an opti-pac and could build or buy a spinner to attach to it...
The other option is to buy Slik Stik's Tornado, which has a USB connection...
Either way I assume, that I need to configure MAME to recognize the spinner, or to use it for a specific game...I looked in the configs, and I didn't really see anything...I assume I would want to be able to adjust sensitivity and stuff too...
Can someone suggest where I can find this information?? (I did some searching on the board and I don't see what I need)...
Thank you,
Matt
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:02:58 pm
Re: Configuring MAME to use a spinner...
« Reply #1 on: September 23, 2005, 10:09:12 am »
fire up TEMPEST/Centipede/Missile Command and use your mouse for now. You'll see the Sensitivity setting when TAB is pressed under Analog settings. MAke sure mouse =1 in the INI file.
Free VGA Breakout Cable
Sinner
    • Geek My Gadget
« Reply #2 on: September 23, 2005, 10:12:55 am »
Thanks...would that be the same for all games???  I tried using a mouse for Arkanoid once, and it wouldn't work...
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« Reply #3 on: September 23, 2005, 10:28:59 am »
Yes thats it.
You may have changed the configuration for a given game to use the arrow keys (for instance).
You also can't configuration the mouse buttons when paused (which can give the illusion that the mouse isn't workign)
Sinner
    • Geek My Gadget
« Reply #4 on: September 23, 2005, 11:05:05 am »
Awesome...thank you...I just tried it with my mouse, and it worked...I really appreciate the info...
