Author Topic: Will I need more than 2 buttons?  (Read 2887 times)
AlanS17
    • AlanS17
« on: July 25, 2005, 05:24:51 pm »
Will I need more than 2 buttons for a vertical classic cocktail cabinet? If so, how many do I need?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: Will I need more than 2 buttons?
« Reply #1 on: July 25, 2005, 05:31:09 pm »
I say stick with jamma standard, 2 player, 3 button.
http://fe.donkeyfly.com/controls/gamesbycocktail.php
If oyu want you can start going through that and see if there are 3 or more button games.  Otherwise if I remember when I get home where I can query tha tdatabase I can tell you if any games in controls.dat need more than 2 buttons that support cocktail.
FYI, asteroids needs a 2 way joystick and 3 button in mame.  So there's one game.  Cocktail support is being worked on for mame.
whammoed
  • Last login:August 23, 2026, 02:42:40 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: July 25, 2005, 05:34:32 pm »
I have a vertical cocktail that I play mostly classics on.  I put three buttons but have never put a game on there that requires more than two.  Asteroids is horizontal, so if you're truly only playing vertical classics you will be happy with 2.
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 10:06:19 am
« Reply #3 on: July 25, 2005, 05:34:49 pm »
There is Vanguard that needs 4 buttons and it supports cocktail mode.
Free VGA Breakout Cable
whammoed
    • NiceMite
« Reply #4 on: July 25, 2005, 05:44:19 pm »
Hmmm, interesting game, never played it.  I couldn't play it with buttons but since I have both an 8 way and a 4 way joystick I could use the 4 way for the buttons since they are directional firing anyway.  Have to check it out ;D
AlanS17
    • AlanS17
« Reply #5 on: July 25, 2005, 05:46:58 pm »
Well I'm interested in using this thing strictly for vertical games. If I ever decide I want to play horizontal games on it I'll add a third control panel to the long side. Then I can put however many buttons I want on it. I also won't be needing screen flipping for that third control panel so cocktail mode wouldn't particularly matter for horizontal games.
AlanS17
    • AlanS17
« Reply #6 on: July 25, 2005, 05:55:53 pm »
The reason I'm even asking about 2 is because if I only need 2 buttons, I'd like to put 2 buttons on the left and right sides of a centered joystick. If I need 3 buttons I'll have to set them to the right of the joystick.
I'd like to be able to have left/right buttons, though. I don't want mine to look like everyone else's. But in order to do that, I'd be restricted to 2 buttons. I just want to know if I can get away with it without mising out on any required games.
SirPoonga
  • Puck'em Up
« Reply #7 on: July 25, 2005, 05:58:29 pm »
well, most games that used 3 buttons put the buttons either in a row or in a triangular fashion.  So you can do your 2 button idea, leave room to add a third button above them for future if you find something...
Thenasty
« Reply #8 on: July 25, 2005, 06:07:28 pm »
here is Vanguard control panel layout.
« Last Edit: July 25, 2005, 06:09:01 pm by Thenasty »
AlanS17
    • AlanS17
« Reply #9 on: July 25, 2005, 06:21:14 pm »
I could fit 4 buttons just as easily as I could fit 2, and I could fit 3 buttons if I formed them into a triangle. I guess it just comes down to how many I think I would need. Maybe I need to play some Vanguard tonight.
88mph
  • Last login:July 30, 2018, 12:17:48 pm
  • I need fuel!
« Reply #10 on: July 25, 2005, 07:10:46 pm »
I have a vertical cocktail cabinet.. one side has a joysitck, spinner, and two buttons.  The other side has a joystick, trackball, and three buttons.
I haven't run across many vertical games that require the 3rd button.. Asteroids and Space Duel benefit from a 3rd button, but you're not getting accurate play on those games with a joystick anyway.. (and you can always remap up or down to help out on those games)  A third button would have been helpful for Star Trek, but that's a spinner game.
I think you'll be fine with 2 buttons.  I've been playing my vertical cocktail cabinet for years and haven't regretted the 2 button layout.
Good luck,
88mph
Avery
  • Last login:May 03, 2013, 12:52:02 am
  • Have fun! Make stuff.
« Reply #11 on: July 26, 2005, 04:09:39 pm »
Set it up this way, with each button firing a different terminal on your encoder and set all your control codes "Button 1 - A or B", "Button 2 - C or D" then if you ever HAVE to have a third button for some obscure game, you can have it be one of the buttons on the far side of the joystick.
It'd going to be a bugger to press, but you would have the option if you ever wanted it.
Avery
AlanS17
    • AlanS17
« Reply #12 on: July 26, 2005, 05:34:25 pm »
The thought had already crossed my mind, but it would be so unnatural that it wouldn't be worth it to me.
