Author Topic: What is the purpose of a Slam switch?  (Read 16424 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: May 31, 2005, 07:53:30 am »
i see there is connection for a slam switch on the centipede wiring harness.
Does anyone know what the original purpose of this was?
SirPeale
  • Green Mountain Man
Re: What is the purpose of a Slam switch?
« Reply #1 on: May 31, 2005, 07:56:24 am »
You abuse the machine (ie SLAM the machine) you lose any credits you put in already.  The machine resets.
Stingray
« Reply #2 on: May 31, 2005, 08:32:38 am »
Kind of like a "tilt" in pinball.
-S
2600
« Reply #3 on: May 31, 2005, 08:56:21 am »
Yep same thing, some cabs call it tilt.  Mame accurately maps these too, which if you haven't remapped and press it in the middle of a game is not fun.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: May 31, 2005, 11:11:11 am »
The slam switch is a holdover from the electro-mechanical pinball machine days. It's purpose was to prevent players from obtaining free credits by beating/kicking/hitting the front door from the vibration of the coin switch contacts.
The switch has also been known as "anti-cheat", "anti-slam", "tilt", and "slap" switch. In the old days it was a normally closed switch and was wired in series with the coin switches. When banging on the door, it opened the circuit thus momentarily killing the coin switch circuit. Modern games that use a tilt/slam switch (like gambling/slot machines) are normally open switches and go to the game board. When the switch is activated the gameboard resets (just like you turned off the power then back on again) and ALL CREDITS are lost. Sometimes an audio alarm sounds! :o
« Reply #5 on: May 31, 2005, 11:30:25 am »
Seems to me someone willing to abuse the machine to get free credits would just abuse it more if they lost their credits.
Q*Bert_OP
  • Oh yes, we did!
« Reply #6 on: May 31, 2005, 11:44:56 am »
Actually in cerain games the slam switch does nothing except when a slam and a credit are registered, act as if nothing happened.
Stingray
« Reply #7 on: May 31, 2005, 11:48:48 am »
Really? What key is mapped to by default? I'm pretty sure I have a slam switch in my parts box. I might wire it in just for kicks.
-S
rchadd
  • Made in Cornwall
« Reply #8 on: May 31, 2005, 12:05:00 pm »
also my centipede coin door has lockout thingies
looks like when electric is applied a little bolt comes out out it to prevent the coin mech from accepting any coins when they are accepted.
now when would that be required?
coindoors were pretty complicated things back in those days
2600
« Reply #9 on: May 31, 2005, 01:26:58 pm »
-S
I think the default is 'T', but some games may have it differently.  Quick Check of Centipede and NARC have it as 'T'.
I remember there being a thread on this a while ago, and people were describing the different ways the actual switch was implemented.
clonestar
  • Last login:March 09, 2009, 04:00:53 pm
  • Thunderbirds are puppets!
« Reply #10 on: May 31, 2005, 02:02:22 pm »
Most pinballs had lockout coils in the door, I think the purpose of this was to prevent credits being applied during the game, not sure why but as pinball didn't have any sort of "continue" option untill the 90's not a problem.
clonestar
« Reply #11 on: May 31, 2005, 02:07:12 pm »
Ok, I looked a bit further, this lockout served two purposes,
  • To lock the coins slots during startup and self test, presumably in case the machine didn't register the credits then plus if it never made it all the way up no money had been lost.
  • When maximum credit had been reached to prevent further coins being deposited
rohan
  • Last login:December 30, 2011, 08:24:04 pm
  • I'm a winner.
« Reply #12 on: May 31, 2005, 05:27:19 pm »
I wonder of Midway's Space Invaders originally had one of these.  The one at a local arcade gives me credits if I tap firmly on the coindoor, but resets when I do it too hard.
It doesn't matter if you win or lose....it's how you play the videogame.
Q*Bert_OP
  • Oh yes, we did!
« Reply #13 on: May 31, 2005, 11:59:33 pm »
Hey, I wired mine up, and it becomes anoying in games like tempest and space invaders.
Stingray
« Reply #14 on: June 01, 2005, 11:09:43 am »
I know for sure that the cocktail version has a slam switch, I assume the upright must too. I've never tapped on the coin door on mine to see if I can get it to register free credits. I'll have to try that next time I play it.
-S
rohan
  • I'm a winner.
« Reply #15 on: June 01, 2005, 03:05:35 pm »
The version I'm referring to was an upright SI, but I think the cocktails had the same coindoors.  I actually feel bad when I do this because arcades make such little money as it is, and games are only one token.  They're pretty cool tokens at that:
whammoed
  • Last login:September 03, 2026, 12:19:35 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #16 on: June 01, 2005, 03:44:38 pm »
Those are cool tokens...If I paypal you some $ will you send me a few (at your leisure)?
rchadd
  • Made in Cornwall
« Reply #17 on: June 05, 2005, 05:09:13 pm »
here is a picture of the slam switch on my centipede coindoor
the orientation is wrong - should be rotated 90 anticlockwise
the weighted actuator hangs downwards
presumably when the door is slammed it will swing and activate the switch
« Last Edit: June 05, 2005, 05:11:02 pm by rchadd »
Ken Layton
  • Guru
  • Technician
« Reply #18 on: June 05, 2005, 10:40:44 pm »
That slam switch with the blue microswitch must be for a foreign coin door. In all my years of coin machine repair, I've never seen one setup like that. All USA coin doors use a leaf switch with a weight on the end as a slam switch.
rchadd
  • Made in Cornwall
« Reply #19 on: June 06, 2005, 05:47:47 am »
the coindoor was either from UK or Germany
Stingray
« Reply #20 on: June 06, 2005, 11:45:01 am »
I've got  couple in my parts box and one installed on my SI. They're all the wieghted leaf type. Never seen one with a microswitch.
-s
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #21 on: June 06, 2005, 04:29:46 pm »
Just so people known what Ken is talking about....I snapped a shot of my coin door as  an example. You can see the weighted leaf switch in the upper left corner.
**Edit: fixt
« Last Edit: June 07, 2005, 04:24:04 pm by M3talhead »
Signature tags are dumb.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #22 on: June 06, 2005, 04:34:46 pm »
NO MORE!!
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 09:49:02 am
« Reply #23 on: June 06, 2005, 07:05:44 pm »
I know, you might go blind, M3talhead Slamswitch is Invisible
Free VGA Breakout Cable
