Author Topic: Mame 96u3 is out, here is the scoop  (Read 1505 times)
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
« on: May 25, 2005, 11:00:53 pm »
0.96u3
MAMETesters Bugs Fixed
openice096u2red
1945kiii096u2gre
capbowl096u1gre
Source Changes
Fixed Wizz Quiz clone. [Pierpaolo Prazzoli]
Added shadow effects to the SSV driver. [Luca Elia]
Simplified additive path in slapstic code. This should not impact any games
that use it, but it is worth verifying. [Aaron Giles]
Improvements to The Couples driver: Improved the video hardware, added a
preliminary PPI8255 + inputs interface, added a better workaround of the
$b011 jump, and added sound. Now the game is somewhat playable, but there
are still some problems in the game. [Angelo Salese]
Fixed DIP switches in several games:
* Dream Soccer '94
* Major Title
* Seibu Cup Soccer
* Caveman Ninja (World & US)
* Spinal Breakers
* Play Girl 2
* Rohga
* Shootout
[Brian Troha]
Added 'find' command to the new debugger for performing memory searches.
[Aaron Giles]
Adjusted sound balance in a few drivers. [David Haywood]
Added preliminary video emulation to penocup.c. [David Haywood]
Added better debugging support to the the MIPS and PPC cores. [Nathan Woods]
Improved sound in Hot Shock and Explorer. [Pierpaolo Prazzoli]
Hooked up light gun properly in Golgo 13. [R. Belmont]
Fixed sprites, controls, colors, sound, many graphics problems in Panic Road,
but still not working. [Tomasz Slanina]
Fixed TMS34010 reverse blitters so they didn't perform extraneous source
memory fetches. [Aaron Giles]
Old debugger no longer forces the memory display to 16-bit words regardless
of the size specified with the M command. [Andrew Church]
Fixed OKI sample rate in Dark Seal/Crude Buster. Attempted to fix Vapor Trail
dropped sound commands. [Bryan McPhail]
Changed trace and traceover commands so they can append to existing files by
placing '>>' before the filename. [Nathan Woods]
New games added or promoted from NOT_WORKING status
AmeriDarts [Aaron Giles]
A. D. 2083 [Pierpaolo Prazzoli]
New clones added
Welltris (World) [Aaron Giles]
Express Raider (US set 2) [Joachim Bassmann]
The Couples (Set 2) [Angelo Salese]
Moon Shuttle (Japan set 2) [Corrado Tomaselli]
Dungeons & Dragons: Tower of Doom (Euro 940113) [Razoola]
Alien vs. Predator (Hispanic 940520) [Razoola]
X-Men Vs. Street Fighter (Asia 960919) [Razoola]
Street Fighter Zero 3 (Asia 980904) [Razoola]
Giga Wing (Asia 990222) [Razoola]
Hot Memory [David Haywood]
Borderline [Pierpaolo Prazzoli]
New games marked as GAME_NOT_WORKING
Cyber Tank [Angelo Salese]
The Lost Castle In Darkmist [David Haywood/Tomasz Slanina]
SirPeale
  • Green Mountain Man
Re: Mame 96u3 is out, here is the scoop
« Reply #1 on: May 26, 2005, 01:48:14 pm »
It isn't stated in the whatsnew.txt, but I think galaxian.c was fixed too.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:52:04 pm
« Reply #2 on: May 26, 2005, 03:21:34 pm »
Not fixed yet....
« Last Edit: May 26, 2005, 03:35:44 pm by Thenasty »
Free VGA Breakout Cable
