Author Topic: Monitor went black  (Read 2716 times)
ckong
  • Last login:October 19, 2020, 06:48:09 pm
  • Retro Games forever!
Monitor went black
« on: May 24, 2005, 12:39:46 pm »
 ???  A few days ago I enjoyed a nice game of KOF 94 (MVS). Today I wanted to go for another round, but my monitor won't start up. I hear the game playing, I can hear the credit sound, but I have no picture. I tried another MVS game, and a jamma game, but no luck. I do hear game sounds, but I see no picture.
what is going on? As a non-technician I am afraid to pull and push on all kind of things, but I hope there is a simple solution. Or is the monitor dead (I just bought this 14-year old cab last week).
Retroguy
SirPeale
  • Green Mountain Man
Re: Monitor went black
« Reply #1 on: May 24, 2005, 12:49:26 pm »
Look at the back of the monitor while the game is on.  In the 'neck' of the monitor there should be a slight glow.  Is there anything there?
If not, start checking fuses.
ckong
« Reply #2 on: May 24, 2005, 01:31:25 pm »
 :-[ Hi Peale,
thanks for the quick reply. I checked the neck of the monitor. No glow, no sond. So, check the fuses. But where are they? I don't want to touch the monitor PCB board because of high voltage danger.
By the way, all other electronical devices in the cab work (lightbulb, MVS motherboard, gamesystem).
Retroguy
SirPeale
« Reply #3 on: May 24, 2005, 07:38:52 pm »
Fuses may be on the floor of the cab.  Trace the wiring.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: May 24, 2005, 11:47:38 pm »
Fuses for the monitor are generally located directly on the monitor's main circuit board. A Neo-Geo cabinet could have any one of a dozen brands/models of monitors in it. Take a good look at the back of it and go to Bob Roberts' monitor ID page. Then we can advise you what to do.
ckong
« Reply #5 on: May 25, 2005, 02:44:30 pm »
OK,
My Samsung arcade monitor is still black, there is no glow at the neck of the monitor. Theredore a fuse could be broken.
 I take a good look at the monitor PCB. In fact I took a picture of it. see attachment
so, where do I look for a fuse. At first sight I don't see one.
Greetings,
Retroguy
« Last Edit: May 25, 2005, 02:47:29 pm by retroguy »
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 12:21:43 am
« Reply #6 on: May 25, 2005, 04:24:00 pm »
since you have the back door open, maybe is just that Interlock is not pulled out. Check it...
Free VGA Breakout Cable
ckong
« Reply #7 on: May 25, 2005, 05:15:57 pm »
 ??? Hi,
call me stupid, but what is the interlock? Besides, the kast few times I played some games, the backdoor was also open (the lock is broken, I leave the wood panel out to prevent fallen against who knows what.
Retroguy
Thenasty
« Reply #8 on: May 25, 2005, 05:25:42 pm »
the interlock (a switch) would be a device around the inside of the cabinet near the outside somewhere. So when you close the door, it will activate the power. Once you have the door open, it cuts off the power, thats when you need to pull it. Here is pic.
It might look like this to..
http://www.happcontrols.com/amusement/acesor/53703100.htm
« Last Edit: May 25, 2005, 05:30:08 pm by Thenasty »
