Author Topic: Keywiz MAX  (Read 1776 times)
scorpio1968
  • Last login:April 12, 2007, 03:38:41 pm
Keywiz MAX
« on: April 10, 2005, 08:17:36 am »
Has anyone been able to sucessfully get keywiz to launch an alternative key mapping at boot up?  I can not for the life of me get this to work.  I have follwed the intructions but can not seem to find where I am supposed to change the command lines.  by the way I am running Windows ME.
Thanks in advance for your help
Scorpio1968
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re: Keywiz MAX
« Reply #1 on: April 11, 2005, 10:45:31 am »
not sure what you mean "at bootup"? explain in more details what you're trying to do and what you have done so far.
Tiger-Heli
    • Tiger-Heli
Re: Keywiz MAX
« Reply #2 on: April 11, 2005, 12:07:52 pm »
Haven't tried it at boot-up, but have got it to work using batch files.
See http://forum.arcadecontrols.com/index.php/topic,34895.0.html or E-mail RandyT.
BTW, I had a problem with the batchfiles not working after Windows detected and installed a Standard Keyboard Driver for it.  Delete one of them if you show two in Device Manager.
And yeah, post what you've tried so far.
chemame
  • Last login:January 26, 2007, 01:54:05 pm
Re: Keywiz MAX
« Reply #3 on: April 11, 2005, 02:57:38 pm »
Randy is really cool when it comes to support for his stuff.
Back when I first got my keywiz, I couldn't get the auto-loading profiles to work... I emailed him with my question, and with the commandline params and so forth...
...and he immediately saw a problem in the syntax of the switches I was sending (I was sending /a /pa and it should have been /a /p a... or was it the other wat 'round....?  :)
In any event, just from the wording of his response, I knew immediately that when I got home and tried it, it would work. Nothing like the tech support disaster IOmega gave me... http://www.crazykennas.com/base/index.php?menu=Dave%21
scorpio1968
Re: Keywiz MAX
« Reply #4 on: April 12, 2005, 01:14:49 pm »
Thanks to all of you that responded.  I did get in touch with Randy and my problem is solved.  Great product but even better customer service.  All I was trying to do was get around screens that ask you to type OK.  Randy told me to move the joystick left then right.  Simple solution to a problem I apparently was way over thinking.  This site and all of your help is greatly appreciated.
Thanks again
Scorpio1968
Tiger-Heli
    • Tiger-Heli
Re: Keywiz MAX
« Reply #5 on: April 12, 2005, 01:21:05 pm »
Huh???  That's a WAY different question then what you asked.  But there are other answers to that.  Search on "OK Screens" in this forum.  It gets asked about once a week.
