Author Topic: playchoice power supply question  (Read 4829 times)
thebestofsteve2
  • Last login:May 08, 2012, 02:20:16 pm
« on: February 28, 2005, 08:48:00 pm »
HI, I am restoring a nintendo playchoice single monitor game. I need a power supply. Is the playchoice power supply unique or is there another nintendo power supply that I can use in place? (Popeye? Vs?) I have been having trouble locating a "playchoice" power supply so I might have to either use a compatable replacement or customize one.  thanks, Steve
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
Re: playchoice power supply question
« Reply #1 on: March 01, 2005, 12:22:34 pm »
for some reason i feel like paige will know this answer... so i will bump this for you
"Owens is the ringleader in the ass hat circus"  D K
thebestofsteve2
« Reply #2 on: March 02, 2005, 03:25:54 pm »
Thenasty
  • Trade Count: (+17)
  • Last login:September 24, 2026, 01:17:38 pm
« Reply #3 on: March 02, 2005, 04:56:28 pm »
if you need a Nintendo PS, I have one. Its the one with the 100Vac and 110 VAC. I can take a pic if so.
Free VGA Breakout Cable
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #4 on: March 02, 2005, 05:02:18 pm »
I saw one on eBay!  Its a power supply for Nintendo vs.  Search on eBay under Collectables -> Arcade, Jukebox, whatever -> Arcade.  Dont remember the price though
APFelon
  • Last login:January 11, 2026, 06:54:36 pm
« Reply #5 on: March 02, 2005, 05:07:20 pm »
Hm. Somehow I doubt that it is any different that the usual +5 -5 +12 power supplies that are such common fare nowadays... Have you located a manual and / or schematics for a Playchoice yet?
APf
Thenasty
« Reply #6 on: March 02, 2005, 05:16:09 pm »
are we talking about a PS that has the 5v, 12v etc...or are you talking about PS for Nintendo Monitor ?
If so, you can just buy those PS for around $35.00 or so but if its a
Nintendo Monitors, it wants 100vac not 110-120vac carefull before you blow up the monitor.
Pipercub
  • Last login:December 08, 2009, 10:59:48 pm
  • My living room is a F'n arcade
    • Subaru Brat
« Reply #7 on: March 02, 2005, 05:24:02 pm »
It has some odd-ball 24 or 36 volt output on one pin but that is only to incriment the mechanical coin counter and you could just ditch that or if you must, replace it with a 12v unit.
thebestofsteve2
« Reply #8 on: March 02, 2005, 09:00:56 pm »
Thanks for the help guys. I did some more research. I found several schematics and manuals for the playchoice 10, however, the only ones I could find are for the dual monitor version. I need to run a single nintendo monitor. The power source model is PP-1000A (again, for dual monitor). I found the power source pinout at  http://basementarcade.com/arcade/library/manuals/p/pch1-up.pdf
take a look at page 22 on the pdf file.
Thanks, Steve
