Author Topic: 21" Pc monitor in 19" cab  (Read 1216 times)
Kubit
  • Last login:May 29, 2005, 03:29:26 pm
« on: February 22, 2005, 11:18:46 am »
I've got a silverline jamma cab that I had to take the original 19" arcade monitor out of. I want to maximise screen size and figure that a decased 21" PC monitor should be roughly the same size.
Has anyone managed to fit a 21" PC monitor in their jamma cab and get the back on ok? I'm guessing most 19" jamma cabs are roughly the same size.
Also, when decasing a PC monitor does the tube extend all the way back to the plastic casing? (In which case I can just measure the monitor cos it's the depth that seems most likely not to fit.)
Nocturnaloner
  • Last login:May 05, 2016, 12:39:53 pm
  • AARRRRcade!
Re: 21" Pc monitor in 19" cab
« Reply #1 on: February 23, 2005, 12:59:44 pm »
I can't say what will fit in your cab, but I can say that almost all modern pc monitors have a metal cage that surrounds the tube, just under the plastic casing, and yes, the tube (or the electronics it's conected to) extends back all the way.
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #2 on: February 23, 2005, 04:07:01 pm »
Speaking of the metal cage surrounding a monitor chassis, when I replaced the WG in my Gauntlet cab, I used a 21" NEC and had to leave the back of the cabinet open so I didnt crush the cage. It was a bit of a pain since the cab wouldnt butt up against the wall completely. It stuck out about 1-2 inches, but if I remember if I removed that cage, the chassis would be exposed. Not the best thing to have.
Signature tags are dumb.
