Author Topic: VGA to RGB adapter?  (Read 5384 times)
Aqualung
  • Last login:October 25, 2002, 08:44:35 am
  • Hi-quality Brazilian disaster
VGA to RGB adapter?
« on: October 24, 2002, 09:29:09 am »
Hi everybody, here I am with another dumb question:  ;D
I got a very good offer of a 21" arcade monitor with RGB connectors, but as my cabinet was built from scratch I don't have the JAMMA connectors to plug this arcade monitor in.
So here's my question: is it possible to build a VGA to RGB adapter so I can plug it on my video card? Or where I can buy a pre-made one?
Thanks a lot.
* Edited: I meant VGA to RGB, not the inverse.
« Last Edit: October 24, 2002, 10:55:21 am by Aqualung »
SNAAAKE
  • -Banned-
Re:RGB to VGA adapter?
« Reply #1 on: October 24, 2002, 10:10:30 am »
there is no rbg to vbga adapter :P.
BUT,scan converter will do.Down scan converter.I am still trying to find a good solution on using arcade monitor and pretty much there with arcade monitor. ;D
Dink
« Reply #2 on: October 24, 2002, 10:23:04 am »
Well, there are RGB to VGA adapters:
http://www.magenta-research.com/cables_accessories/video_adapters.html
They're just not going to work the way you want them too with your arcade monitor.
Start here for more info:
http://www.arcadecontrols.com/arcade_monitors.shtml#Sync
« Last Edit: October 24, 2002, 10:25:41 am by Dink »
Aqualung
« Reply #3 on: October 24, 2002, 10:53:45 am »
In fact, I believe I stated wrong what I want: it's a VGA to RGB converter, because the signal will go from the video card to the arcade monitor, right?  ;D Sorry about the mistake, SNAAAAA(...)AAAKE and Dink.
If helps, my video card is a Geforce 2 MX 400 AGP with s-video and composite out. If this doesn't work, I also have a Voodoo 3 2000 PCI card.
BobA
  • What Me Worry?
Re:VGA to RGB adapter?
« Reply #4 on: October 24, 2002, 11:04:45 am »
VGA to RGB often called PC2JAMMA even if you do not have a jamma connector the rwiring from the PC to the Arcade monitor is covered at the link below.
http://www.mameworld.net/pc2jamma/pc2jamma.html
Use the link on the left of the home page PC2JAMMA and then the link at the top called video,
BobA
Aqualung
« Reply #5 on: October 24, 2002, 11:23:06 am »
BobA
Thanks BobA, I was just reading this site when I saw your post  ;D
Now I see that it's possible to hook the arcade monitor on the video card. But there's one thing that I'm still lost: is is possible to use the arcade monitor with Windows? I'm using WinME and personally hate DOS.
And as I saw on ArcadeOS and Dragon's Den, they're all using DOS. But I'm going to pay some Windows games too - like Pro Pinball.
It's possible to use Windows? If not, I'm going to screw all this idea up and put a television on my cabinet instead.
SNAAAKE
  • -Banned-
« Reply #6 on: October 24, 2002, 12:03:34 pm »
instead.
answer is NO.
Like I said,either get a scan converter or wait for andy's 15khz ati based grafic card that outputs windows to arcade monitor.
Aqualung
« Reply #7 on: October 24, 2002, 12:08:21 pm »
answer is NO.
Looks like I'm gonna buy this arcade monitor and keep on the closet until Andy releases his video card. It's a VERY VERY VERY good offer I can't lose.
Anyway, thanks a lot to everybody.
