Author Topic: Monitor question (technical)  (Read 3726 times)
Elkor
  • Last login:February 12, 2007, 12:42:50 pm
  • What did I just say?
    • Full Circuit
« on: October 19, 2002, 10:32:59 am »
I have a 28" hantarex mtc9000 out of an old operation thunderbolt game.  as this was a shooter, the monitor was originally mounted horizontally and viewed with a mirror.  I plan on mounting the monitor for direct viewing but can't figure out how to correct the video signal  (it displays reversed)
I know this shouldn't be hard, can anyone help?
please?!?!???
-C
The sudden sight of me causes panic in the streets. They have yet to learn
-- only the savage fears what he does not understand.
                -- The Silver Surfer
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 10:53:28 pm
Re:Monitor question (technical)
« Reply #1 on: October 19, 2002, 11:14:06 am »
What do you mean it displays reversed ? Do you mean the original game Operation Thunderbolt ? You trying to view it direct, or you trying to do with MAME ?
Free VGA Breakout Cable
Elkor
    • Full Circuit
« Reply #2 on: October 19, 2002, 11:52:14 am »
Originally, the monitor was mounted horizontally and viewed with a mirror.
Because of this, it was configured to display everything reversed (so that to the player the text would be legible).
Now, I have the monitor mounted vertically (direct-view, no mirror) and I have to figure out how to un-reverse the video signal.
Yes, I'm using mame (advmame); but this is definately a monitor hardware-thing (I have a streetfighterII board here, when plugged in that displays reversed as well)
If possible, I would like to make the monitor display correctly.
I know that advmenu has a "mirror" option, but I cannot find a similar setting for advmame, so while I can get the frontend to display properly, any games launched are 'reversed'.
once again, I would be gratefull for any help (at all!)
-C
Elkor
    • Full Circuit
« Reply #3 on: October 19, 2002, 01:02:41 pm »
Got it working!
one of the guys from the advancemame-users list helped me out.
thanks anyway nasty!
-C
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #4 on: October 19, 2002, 11:32:28 pm »
Got it working!
-C
for historical purposes, and curiousity, and the odd chance some one else will have this problem in the future... what was the solution?
rampy
MameFan
« Reply #5 on: October 20, 2002, 12:35:01 am »
Sounds like you needed to just swap the yoke wires around.
Red+Blue,  Green+Yellow
Flip them both(red on blue, blue on red, green on yellow, yellow on green) and you essentially rotate the monitor 180 degrees.
If you're only experiencing a "mirror" image, then you just swap one of the 2, depending on the axis it's mirrored.
Red/Blue = Horizontal (widest measurement of screen)
Green/Yellow = Vertical (shortest measurement of screen)
Elkor
    • Full Circuit
« Reply #6 on: October 20, 2002, 01:53:46 am »
yup, just switch the pairs around as needed.    I needed to swap both pairs
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #7 on: October 20, 2002, 02:58:36 am »
same thing with those 19" Eygos that were on ebay (I have one).
