Author Topic: advmame, dos, and tbalde64 install  (Read 1579 times)
vincentc77
  • Last login:May 11, 2020, 08:14:22 pm
« on: January 28, 2005, 10:03:26 am »
I'm finally getting all of the pieces and knowledge together inorder to try getting my 25kHz monitor to properly display the advcfg setup screen.  I'm going to try these steps tonight:
- set pclock at 5-90
- set hoz freg at 24.9 KHz
-set vetical freq at 47-63 Hz.
- play with shift 'i'
-increase/decrease horz freq by .01
-repeat until screen is viewable.
-Does anyone know if any special lines in the rc file  are needed for the tblade 64, or any TSRs?  Remeber this is for DOS using a WG U3000 EGA arcade monitor.   Anyone want to add anything?
Thanks,
Charlie
whammoed
  • Last login:May 16, 2026, 10:42:15 am
  • Crack don't smoke itself
    • NiceMite
Re: advmame, dos, and tbalde64 install
« Reply #1 on: January 28, 2005, 10:21:00 am »
Yes,
I thought the U3000 was a 31Khz monitor?
http://www.happcontrols.com/monitors/49083200.htm
vincentc77
« Reply #2 on: January 28, 2005, 11:23:41 am »
The model number is 33K3201, according to WG.  It was in an NFL Blitz cab which is an EGA game.
Charlie
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 10:09:41 am
« Reply #3 on: January 28, 2005, 11:55:06 am »
Free VGA Breakout Cable
whammoed
    • NiceMite
« Reply #4 on: January 28, 2005, 12:03:45 pm »
I imagine it may be possible to adjust the horizontal frequency on that monitor to get it to sync with 25hz instead of 31hz.  I had a U3100 that you could adjust quite a bit/
rockmes
  • Last login:June 05, 2016, 09:41:38 am
  • Don't you love it?
« Reply #5 on: January 30, 2005, 07:20:18 pm »
you will find what you need on this site- the tsr and the setting you need
http://easymamecab.mameworld.net/
