Author Topic: Powering the coin door lights  (Read 1740 times)
Beeeph
  • Last login:October 18, 2006, 12:31:44 pm
« on: December 29, 2004, 09:50:42 pm »
after buying a used but functional coin door w/mechs for $20 on ebay :o, I was confused a bit by the wiring:
with this connection, it looks like I can directly hook up two standard molex connectors from my PC power supply.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 09:20:40 pm
Re: Powering the coin door lights
« Reply #1 on: December 29, 2004, 09:54:51 pm »
jsut cut/trace the wires from the bulb (looks like green/blue) and then make sure what voltage those lamps accept and use the PC power supply to hoo it it. RED wire on PC is 5volts and yellow is 12V.
Free VGA Breakout Cable
terryd
  • Last login:October 27, 2005, 03:14:58 pm
  • To each his own... Unless I want it first!
« Reply #2 on: December 29, 2004, 10:34:18 pm »
How do you find out what voltage the bulbs are?  Is there an indicator on them?
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« Reply #3 on: December 29, 2004, 10:45:40 pm »
Try it with 5v, and if that's too dim move up to 12v.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: December 29, 2004, 11:39:13 pm »
Take the bulbs out of the socket and look at the numbers on them.
Here are typical bulbs and voltages:
159, 259, and 555 are all 6 volts
161, 194, and 658 are all 12 volts.
