Author Topic: How do I make a hacked vga cable??  (Read 2056 times)
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« on: December 13, 2004, 06:39:33 pm »
Hey anyone know how to hack a vga cable? Im trying to figure out which color wire does what...
I have wires that range from.....
Brown, Yellow, Gray, Purple, Pink, White, Blue, Red, Green, Black, Orange, Black (with white line on it), Brown (with white line on it), very light Blue wire, and some exposed wire (I suppose its a ground wire??)
I suppose I want to find the R,G,B,Syncs, and ground...help me please!!
SirPeale
  • Green Mountain Man
Re: How do I make a hacked vga cable??
« Reply #1 on: December 13, 2004, 07:07:18 pm »
Get a multimeter.  Get the VGA pinout from Google.  Put one lead on a pin, the other on the wire end.  Note what wire does what, and label the wires.  Repeat until done.
Thenasty
  • Trade Count: (+17)
  • Last login:June 18, 2026, 10:57:35 pm
« Reply #2 on: December 13, 2004, 09:25:56 pm »
there easy to make, but if your not up to it, I still have some for $6.00 shipped.
Here is a link for pin outs.
http://www.mameworld.net/pc2jamma/pc_arc3.html
« Last Edit: December 13, 2004, 09:28:56 pm by Thenasty »
Free VGA Breakout Cable
stellarola
« Reply #3 on: December 13, 2004, 10:49:55 pm »
Yea, I'll buy one, whats ur paypal! :D
Thenasty
« Reply #4 on: December 14, 2004, 12:00:18 am »
check PM
quarterback
« Reply #5 on: December 14, 2004, 02:59:00 pm »
Questions (since I don't totally understand this process):
- So this 'hacked vga cable' enables you to attach the VGA 15-pin output of your PC's video card directly to a monitor?
- The 15-pin connector is at one end, what kind of connectors are at the other? (the mameworld.net page says that you "wire the correct output from the VGA port to the correct pin on the JAMMA fingerboard", but I am under the imprssion that the hacked cable will connect right to the monitor)
- Does this then negate the need for an ArcadeVGA card?
- If I were to get a J-Pac, then I would not need a cable like this, correct?
- I've got a PCI ATI RageXL card.
« Last Edit: December 14, 2004, 03:18:58 pm by quarterback »
-- Chad Tower
