Author Topic: is there any other way to adjust  (Read 1334 times)
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 03:22:53 pm
« on: December 04, 2004, 03:07:16 pm »
I have this new WG7203 19"CGA Monitor and I have tried all the adjustment but the screen is still not centered correctly from left/right of the screen.
The left side of the screen is THICKER than the right and if I use the adjustment on the PCB to centered it, the image will be cut off and it folds over.
For example, Pacman (monitor mounted vertically, so now we will be talking about the TOP and Bottom of the screen). The top of the screen will be cutoff only showing the score and the 1up and 2up is cut off. The bottom part where the Cherry and remaining Pac lives, shows but the screen down there is THICKER/BIGGER so there is a big black empty space. So if I could use the PCB controls to move down the screen, I could center it but what happens is that when the 1up/2up will clearly shows, the cherry/pac lives remaining will fold over. The adjustment on the PCB to shrink both ends is max out, if I adjust it the opposite side, it will expand both sides (top/bottom).
I hope I made sense here. Now is there another way to adjust this problem I have thru the NECK of the tube ?
Free VGA Breakout Cable
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: is there any other way to adjust
« Reply #1 on: December 04, 2004, 03:24:01 pm »
Have you adjusted your horizontal width coil?
You will need to tool to do so.
They usually look something like
http://www.gammaet.co.kr/product/prodimgs/grp6.gif
Later,
dabone
Thenasty
« Reply #2 on: December 05, 2004, 02:19:55 pm »
thanks, but this WG-7203 does not have  Hor-Width coil like my old 46xx or 49xx series.
