Author Topic: DOS games in NT???  (Read 1392 times)
Demon-Seed
    • DemonCade (WORKING URL!)
DOS games in NT???
« on: November 23, 2004, 10:35:28 am »
I have been adding PC classics to mamewah etc... many dos games do not work.. anyone help me out????? says not supported by nt etc..... I have been trying to get blood 2 to work with no luck any suggestions? is there a way or am I out of luck?
Thenasty
  • Trade Count: (+17)
  • Last login:April 12, 2026, 10:15:29 am
Re: DOS games in NT???
« Reply #1 on: November 23, 2004, 11:25:39 am »
DOS MAME won't even work under NT. Most likely all DOS program will not work under NT ( at least the ones I tried). Maybe the DOSBOX emulator (if its NT compatible) would be your best bet.
Free VGA Breakout Cable
calicyco
  • Last login:February 25, 2005, 07:46:59 pm
« Reply #2 on: November 24, 2004, 03:31:11 pm »
True DOS games will not work in NT, because of the way they handle the hardware. The "dos" window in NT is a simple command shell that emulates dos in certain ways, and will not run any game that manipulates video modes or audio. Games like Blood, Hexen, etc. will not work properly in an NT command window.
Demon-Seed
« Reply #3 on: November 24, 2004, 03:44:13 pm »
dam I am very sorry to hear that.. i loved blood
calicyco
« Reply #4 on: November 24, 2004, 03:50:59 pm »
Get yourself a dos boot floppy, make a small FAT partition, install blood, reboot via the floppy and play!  :)
Also, you may be able to get it to run via a dos VM in vmware. That MAY work in NT.
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #5 on: November 25, 2004, 04:08:29 pm »
What about dosbox? I have not used it personally, and to tell you the truth I do not know if it would work under NT, but it is worth a try.
Demon-Seed
« Reply #6 on: November 25, 2004, 06:24:49 pm »
Hey I tried it.. it got games to install but they wont run says they wont run under msdos.. and wont run under nt when i try to run them
StephenH
« Reply #7 on: December 01, 2004, 05:43:23 pm »
If you upgrade to XP (or possibly 2000), you may be able to enable Windows 95 compatibility mode, and that may allow them to run.
Demon-Seed
« Reply #8 on: December 02, 2004, 07:12:23 am »
nah i tried it windows compat mode dont work
