Author Topic: is a universal coin mech useless  (Read 1470 times)
Pieman2004
  • Last login:July 15, 2009, 11:29:57 pm
« on: November 15, 2004, 10:40:20 am »
I got a free cab a while back, and it came with a coin door without the coin mechanisms. I haven't really messed with trying to get the coin door working at all untill this weekend. Well I looked it over and underneath where the coin mechs would go there was a switch that was activated when a coin was dropped through the slot. Now do all coin doors have this switch or are there some that have the switch in the coin mech?
Anyways I decided to rig up something that my coins could go through to reach it from the top to the switch. two pieces of paper and some duct tape later my coin door worked with any type of coin that would fit through the opening. I plan on making a metal channel or something better than paper and duct tape, but I wanted to know if this method would work.
So I was wondering if there is really any advantage to having a universal coin mechanism over a metal guide that the coins just fall through?
pcates
  • Last login:January 05, 2011, 08:15:57 pm
Re:is a universal coin mech useless
« Reply #1 on: November 15, 2004, 11:10:32 am »
There is no advantage to buying a universal coin mech, unless you are trying to prevent certain types of slugs, metal objects, or other stuff from registering credits. If your main purpose is to drop something (anything) into the slot and get credits, you have solved the problem ;) Coin mechs only prevent slugs, and other junk from getting credits. But yours should work fine now with anything, as long as in hits the switch at the bottom.
Thenasty
  • Trade Count: (+17)
  • Last login:December 17, 2025, 10:15:06 pm
« Reply #2 on: November 15, 2004, 11:55:12 am »
if you want to make it more legit, here is how.
"The Ultimate All in One Coin Mech"
http://www.arcadecontrols.org/yabbse/index.php?board=2;action=display;threadid=19200
Free VGA Breakout Cable
