Author Topic: PC Monitor "HourGlass"  (Read 2219 times)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« on: September 28, 2004, 11:38:56 pm »
I've acquired quite a number of 14-15" monitors over the last couple of years, namely from repair/replace/upgrade of PCs for classrooms at my children's childcare facility along with friends/family/family friends.
I decided to test a number of these this evening to try and clear out what is not worth keeping.
I have a couple that are exhibiting what I call an "hourglass" display, that is, the sides are slightly curved inward like:
Understanding that I have more than what I would need for any immediate projects, should these just be pitched or is there some internal adjustment that might get these back to:
I look forward to any replies.
sonicflood
  • Last login:August 19, 2005, 11:22:40 pm
Re:PC Monitor "HourGlass"
« Reply #1 on: September 29, 2004, 12:11:43 am »
That's called pincushion.  Check the monitor for a pot (dial) on the back of the monitor for this adjustment.  Some old monitors had a hole in the back that you need to use a small screwdriver to access.
Also, here's a link to a downloadable program that is quite useful in calibrating a monitor.
Here's the link to get the program for free from Nokia: http://www.construnet.hu/nokia/Monitors/TEST/monitor_test.html
The program leads you through the following tests:
Geometric Tools: size, distortion (pincushion or barrel), tilt, trapezoid and orthogonality.
  • Brightness / Contrast
  • Convergence
  • Focus
  • Resolution
  • Readability
  • Moire
  • Colors
  • Screen regulation
« Last Edit: September 29, 2004, 12:27:55 am by sonicflood »
"Oh, you should never never doubt what nobody is sure about." -Willy Wonka
SteveJ34
  • Trade Count: (+9)
« Reply #2 on: September 29, 2004, 12:01:09 pm »
The "pincushion" monitors in question are Apple Multisync 15AVs which I'm using an adaptor to get to a standard DB15 VGA connector.
There were not adjustments beyond left/right,up/down externally. I popped the case and went  looking for other adjustment mechanisms of which there were several but found none that seemed to affect the pincushion problem.
I guess its possible there is not this type of adjustment available for this old monitor or perhaps this effect is being caused by the adaptor some way?
I don't recall seeing these issues when I shelved these units many moons ago (or I likely wouldn't have kept them at that time) but I have slept since then.
Any suggestions?
Steve
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:38:28 pm
« Reply #3 on: September 29, 2004, 06:20:28 pm »
do like I did,, when you TEST and it don't come out right, GARBAGE, ( I wasted to much tim eon it before) if you need a 15" monitor, goto the surplus or cash converter store they have it for $5.00.
Free VGA Breakout Cable
