Author Topic: WTB: Small Part for Joysticks  (Read 1150 times)
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« on: September 16, 2004, 07:24:01 pm »
I am interested if anyone has any joystick "skirts" larger than those that come standard on a Happs Super - I cut the CP Overlay holes to large, so whne you press up part of the hole can be seen.  Anyone with any they'd be willing to sell?
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 03:59:39 pm
Re:WTB: Small Part for Joysticks
« Reply #1 on: September 16, 2004, 07:56:04 pm »
just make one. I did from a spare siding from the house or any plastic in that matter. Just get a hole cutter (2 size, one for center and outside diameter). First nalil the big piece of plastic you have to a 4x4 then cut the center leaving the DRILL hole in the 4x4 so when you cut the outside diameter, place the drill bit in the mark that it made from first cut so its centered, kabish ?
BTW if yours show the part of the hole, so will other parts will show the hole cause that piece is all the same size.
« Last Edit: September 16, 2004, 07:57:49 pm by Thenasty »
Free VGA Breakout Cable
sc1103
« Reply #2 on: September 16, 2004, 08:11:09 pm »
)Thanks I'll try that
BTW i have seen larger "skirts" - when I bought my junked cab the CPO actually had some glued down...these were much larger (shoulda kept them  :P)
