Author Topic: MAME and "Type ok"  (Read 8912 times)
madk
  • Last login:March 28, 2017, 04:59:49 pm
  • I actually am a llama!!
    • Digital Something
MAME and "Type ok"
« on: August 20, 2002, 01:05:00 pm »
Ok I was just doing some brainstorming to make sure I didn't miss anything before I start my cabinet...and I thought about one thing.  While loading up some roms in MAME if comes up with that "Type ok to continue" prompt.  Now is there anyway to get around this?  I was thinking that once my cp was complete I don't want to have to pull out my keyboard everytime I want to fire up a certain game.  Hrmm..I feel like I am asking a dumb question but it was just something that came to mind.  Thanks.
madk
Matt (mad-k)
hyiu
  • Last login:August 29, 2014, 05:36:15 am
  • too many games... too little time....
    • www
Re:MAME and "Type ok"
« Reply #1 on: August 20, 2002, 01:10:23 pm »
try shaking your 1st player joystick left and right....
that should take care of the ok thing.....
heee heee.....  ;D  ;D
ps: I'm using game pad hack....
Another Brilliant mind ruined by education....  :p
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #2 on: August 20, 2002, 01:23:21 pm »
thjat helped me alot umm will that work with a keyboard hack?
Slow In Fast Out
BombProofPlane
  • Last login:February 11, 2009, 04:14:14 pm
« Reply #3 on: August 20, 2002, 01:42:22 pm »
i heard there was script you can add in cant think of it right now
Thenasty
  • Last login:Today at 03:47:54 pm
« Reply #4 on: August 20, 2002, 01:55:15 pm »
Here are the possiblities.
1. Modify source and Compile your own build (Of course    your not allowed to distribute it, just keep it to yourself).
2. Wiggle Joystick left-Right ( This is the Easiest one...)
3. Use ArcadeOS FE has option to bypass it in the Config.
    Don't have any other clues what other FE does it.
Free VGA Breakout Cable
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: August 20, 2002, 06:47:20 pm »
Yes, keyboards work too.  (try pressing left - right (or the keys mapped to left and right) on your keyboard instead of O - K)
Robin
Knowledge is Power
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #6 on: August 20, 2002, 11:17:24 pm »
cool thanks
Slow In Fast Out
Ryan
  • Last login:October 08, 2009, 10:35:06 am
  • I've been Mamed!!
« Reply #7 on: August 20, 2002, 11:39:01 pm »
That is awesome! :o  Just a little wiggle eliminates two buttons from my control panel plans.  Thanks!
Bear Down!
daywane
  • Last login:September 01, 2026, 05:00:16 am
  • GRRRR!
« Reply #8 on: August 21, 2002, 03:10:41 am »
I have mame 32. we have noticed some mame 32's,  down loaded , let you play the game  with out hitting  "OK" . After the first  time playing. You must hit "ok" the first time ,  but never again after this... ???
8) I just lucked out and this was the first mame I down loaded.
Minwah
    • MAMEWAH
« Reply #9 on: August 21, 2002, 04:27:11 am »
I think all MAME versions operate in this way :)
Thenasty is right tho, compiling your own nag-free version is great ;)
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #10 on: August 21, 2002, 04:35:45 am »
Yeah lovely isn't  ;D
And to all...compiling is not difficult at all. just follow the no brainer instructions on mame.net. After that you only have to adjust two lines off code...and compile it...
Peter
Minwah
    • MAMEWAH
« Reply #11 on: August 21, 2002, 05:58:13 am »
I'm no C programmer, but I managed to do it using mame.net's instructions and a bit of thinking :).
I think the relevant section of source changed slightly in .61 from memory (?).
)p(
« Reply #12 on: August 21, 2002, 06:36:49 am »
true change it to: if(1)
   run_machine_core - core execution loop
void run_machine_core(void)
   /* disable artwork for the start */
   artwork_enable(0);
   /* if we didn't find a settings file, show the disclaimer */
   if (1)
      /* show info about incorrect behaviour (wrong colors etc.) */
      if (1)
Peter
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: August 21, 2002, 06:42:47 am »
Not exactly, MAME is looking for "O or L Arrow or Joystick X-" and "K or R Arrow or Joystick X+", so if your keyboard hack uses "Y" for Left and "G" for right, you won't be able to get past this screen.  You can avoid this without recompiling by reassigning keys:  I found my old notes for it here:  http://www.mameworld.net/emuadvice/ok.doc
Posted by: daywane Posted on: Today at 03:10:41am
I think this is a bug in all MAME's (not MAME32).  It's on MAMETESTERS.  With certain (particularly GRAVIS) gamepads and joysticks, MAME will skip the startup screens.
BTW, to compile your own without nag screens, follow these changes (both 0.61 and previous versions) stolen from the Mameworld compile board:
I've been following these instructions in order to remove mame nags screens. But with 61, somethings seems to be changed.
Open up mame.c and edit line 1195: if (settingsloaded == 0) and change it to: if (0). In line 1202: if (showgamewarnings(real_scrbitmap) == 0) change it to: if (1).
Now, the most similar lines are
502 -> if (settingsloaded || showcopyright(artwork_get_ui_bitmap()) == 0) I change it to if (0)
505 -> if (showgamewarnings(artwork_get_ui_bitmap()) == 0) I change it to if (1)
However, after compiling (with no errors), mame don't work. Do you have the same problem?
Here you go!
502 -> if (settingsloaded || showcopyright(artwork_get_ui_bitmap()) == 0) I change it to if (1)
These are the correct changes try
them and recompile if it still doesn't
work then delete your obj-directory and
start from a clean build.
Good Luck
Rodney
In my custom compile, I also remove the "Bad or missing rom, Press any Key" screens as follows:  (Data provided by Ciro of Emuloader)  (Some of the code has changed since he sent this, but you should still be able to figure it out.
I discover where you can avoid that message (not only "No Good Dump Known",
but "bad CRC" and "bad Size" as well).
Follow these steps:
1. Make a backup copy of the file "mame\src\common.c"
2. Open the file "mame\src\common.c"
3. Go to the line 880 (not sure if this is the exact line)
  You will see this function:
   display_rom_load_results - display the final
   results of ROM loading
  static int display_rom_load_results(struct rom_load_data *romdata)
4. Comment this "IF" sequence (everything, including the " } " character on
the end of it)
  The commentary characters are:
  - to open the commentary use : "  /*  " (without the quotes)
  - to close the commentary use: "  */  " (without the quotes)
  /* if we're not getting out of here, wait for a keypress */
  if (!options.gui_host && !bailing)
   int k;
   /* loop until we get one */
   printf ("Press any key to continue\n");
   do
      k = code_read_async();
   while (k == CODE_NONE || k == KEYCODE_LCONTROL);
   /* bail on a control + C */
   if (keyboard_pressed(KEYCODE_LCONTROL) && keyboard_pressed(KEYCODE_C))
      return 1;
5. Delete these two commented lines from the "IF" statement or the compiler
will generate an error...
6. Save the file and re-compile MAME...
  That's it!!! ;)
PS: Always keep the .o (object files). If you change only one file, you will
not need to wait for all the compilation to be over...
In the compilation folder, just delete the file "common.o" from "mame.obj"
folder (this folder can be different for other types of compilation, mine is
"mameppro.obj" because I use the Pentium optimized compilation)
so it will recompile only the "common.c" file and you will not need to wait
too long... ;)
Hope this helps
Minwah
    • MAMEWAH
« Reply #14 on: August 21, 2002, 07:34:55 am »
I too hide the 'Bad Rom' messages, as this stalls MAME before switching to full screen.  In my frontend, this causes what looks like a 'hang' as the dos-box is hidden, therefore you can never 'Press any Key''.  My FE does have features to cure this problem, but the best option is to compile your own - I believe HowardC has released a version that does just this (although you'll still have the OK screens).
« Reply #15 on: August 21, 2002, 04:19:06 pm »
Yup, it's on the lazarus homepage....  Upon the next release it will have much more though... things like psuedo translucent in game menus with definable colors multi mice support, ect.  That is if the respective mame build creators don't mind me swiping some code.   ;D
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #16 on: August 21, 2002, 07:09:35 pm »
[/b]
Okay, if you want to get technical ;) , MAME is looking for "O or [UI_LEFT]" and "K or [UI_RIGHT]".  (like your notes at http://www.mameworld.net/emuadvice/ok.doc say.)  IMO, you should map UI_left and (game)left to the same inputs, and UI_right the same as (game)right, UI_up & up, etc, but that's up to you.  However this way, if your keyboard hack uses "Y" for Left and "G" for right, you would also use "Y" for UI_Left and "G" for UI_Right, which would mean you would be able to get past the screen.
But you are right I should have said "try pressing leftArrow - rightArrow, which are the default UI_left - UI_right, or, if you changed them, the keys/buttons/joystickdirections mapped to UI_left and UI_right)..."  Thanks for correcting me.
Robin
Knowledge is Power
SirPoonga
  • Puck'em Up
  • Last login:July 07, 2026, 03:00:59 am
  • The Bears Still Suck!
« Reply #17 on: August 21, 2002, 07:24:24 pm »
You'd be amazed at how many people don't know about the O K thing with the left and right, it is in the mame faqs.
madk
    • Digital Something
« Reply #18 on: August 22, 2002, 11:31:00 pm »
Consider me one of them...well not anymore.  But thanks guys!
Matt (mad-k)
