Author Topic: IPAC config file.  (Read 1242 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
IPAC config file.
« on: July 03, 2004, 06:00:41 pm »
How does this file work? Right now I have one configuration for all my emulators. If I want to add an emulator that has different settings, people have mentioned to create an ipac config file and load it with the emulator...
How? I created the config file but how (using batch files) can I load that to the IPAC? Is there a dos command for it?
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 12:23:23 pm
Re:IPAC config file.
« Reply #1 on: July 04, 2004, 05:58:57 pm »
your IPAC must bet set to ALT and use the IPACUTIL for DOS. Just type IPACUTIL on the dos command prompt and it shows you how to use it.
Free VGA Breakout Cable
« Reply #2 on: July 05, 2004, 01:12:19 pm »
Use WINIPAC in Windows, if you use MAMEWAH there is built-in support for IPAC reprogramming (see the Readme for a small how-to).
IIRC 'winipac filename.ipc' will reprogram the IPAC...
