Author Topic: Simple Solution REQUIRED. (dont wanna break nuffin) UPD 27th  (Read 1841 times)
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
« on: March 26, 2004, 07:04:36 am »
Hello All.
Im just about to get a 2player jamma based cabinet.
I want this to be a clean no soldering splicing modding of any kind job ( dont mind playing with software though)
What is the easiest way to connect this to a pc?
( I have been reading lots of posts and from my understanding a ArcadeVGA card and a J-Pac card should wrap it all up nicely? )
If i go that way i will be using the monitor horizontally, can i still play vertical games?
( im guessing they will look squashed a little but the correct ratios? )
That all being said can i use mamewah and the cmdline mame to get a front end and pretty it up?
( once again from what i have read it should be possible? )
Any help here is good help...  Thanks
« Last Edit: March 26, 2004, 10:52:27 pm by Acids »
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 12:01:00 am
Re:Simple Solution REQUIRED. (dont wanna break nuffin)
« Reply #1 on: March 26, 2004, 08:32:21 am »
Hello All.
YES
YES! ! !
YES ! ! !
Free VGA Breakout Cable
SirPeale
  • Green Mountain Man
« Reply #2 on: March 26, 2004, 11:44:06 am »
You don't need an ArcadeVGA if you have a card that will output 15KHz.  Since you can pick a card like that up for just a couple bucks, it's not worth it IF you pair it with a J-PAC.
Acids
« Reply #3 on: March 26, 2004, 10:51:35 pm »
Without having the arcade cabinet. (its comming real soon)
Is there any way i can confirm that my video card can produce 15KHz?
The card is a Asus 3DP - V264GT/PRO i Think?
Windoes calls it a ATI Rage II + PCI (ati_m64)
SirPeale
Re:Simple Solution REQUIRED. (dont wanna break nuffin) UPD 27th
« Reply #4 on: March 27, 2004, 10:01:07 am »
It should.  It's an ATI card.
