Author Topic: Cruis'n USA runs too fast  (Read 7129 times)
mrchrister
  • Last login:December 22, 2025, 11:48:23 pm
« on: March 23, 2024, 08:32:04 am »
I'm having issues with Groovymame and Cruis'n USA. It runs at around 150% speed on my Groovymame setup.
The game has a resolution of 512x400 at 57.2hz. It is the only game of the 10 or so games I tested that switchres seems to have trouble with. I'm using GM .261 with default install. CPU is 8700k.
I found a fix by disabling modeline_generation in mame.ini but I wonder if other folks have that same issue.
Here is the info I get at command line:
Code: [Select]
c:\arcade\mame>groovymame.exe crusnusa
Switchres: Calculating best video mode for 512x451@57.349014 orientation: normal
Switchres: Modeline "2560x464_60i 15.684955KHz 57.349014Hz" 54.175835 2560 2777 3021 3454 464 487 493 547 interlace  -hsync -vsync
a-19993.u38 ROM NEEDS REDUMP
a-19670.u43 ROM NEEDS REDUMP
a-19668.u52 ROM NEEDS REDUMP
a-19671.u54 ROM NEEDS REDUMP
a-19673.u111 ROM NEEDS REDUMP
a-19672.u114 NOT FOUND (NO GOOD DUMP KNOWN) (tried in crusnusa)
c31boot.bin ROM NEEDS REDUMP
WARNING: the machine might not run correctly.
Switchres: Calculating best video mode for 512x400@57.349014 orientation: normal
Switchres: Modeline "2560x512_58i 15.857002KHz 57.349014Hz" 54.976227 2560 2780 3027 3467 512 515 521 553 interlace  -hsync -vsync
Average speed: 146.46% (63 seconds)
c:\arcade\mame>
« Last Edit: March 23, 2024, 08:38:02 am by mrchrister »
haynor666
  • Last login:January 03, 2026, 01:58:04 pm
  • retro maniac
mrchrister
Re: Cruis'n USA runs too fast
« Reply #2 on: April 15, 2024, 10:39:26 am »
Thanks for your reply, but I'm not sure that's the same problem.
1. Regular mame does not have the problem
2. When disabling modeline_generation it works at the correct speed
It seems to be a bug in switchres picking a wrong mode line for the game
Rion
  • Last login:January 05, 2026, 12:28:07 pm
  • 240p, 480i
« Reply #3 on: April 23, 2024, 03:29:10 am »
Have you tried forcing 512x400@57.349016 Hz 31kHz I'm a swirchres ini override file?
Calamity
  • Moderator
  • Last login:Today at 12:00:46 pm
  • Quote me with care
« Reply #4 on: April 29, 2024, 11:55:24 am »
This should be fixed on 0.265, please confirm.
Steps to create a log:
haynor666
  • retro maniac
« Reply #5 on: May 12, 2024, 04:54:44 am »
I'll prepare my build and test on next week. I didn't play arcade games for some time :/
squawkbox
  • Last login:October 08, 2024, 03:39:14 am
  • MAME and GroovyMAME fan!
« Reply #6 on: August 14, 2024, 10:10:55 pm »
Hi guys
New French member here :)
With GM 0.261, on my machine (much less powerful CPU than the OP's), said game runs indeed too fast (Average speed: 120.82%) and fails to pick up the right vertical resolution
Same in GM 0.265, it runs at the wrong speed, aka at the average speed of 78.07%
while in GM 0.228 (the version I use on a regular basis), it runs at the average speed of 99.98%, picks the right vertical resolution and screen refreshes itself at 57.928295Hz
Unlike what happens with 0.261 and 0.265, command line doesn't issue the following line
Switchres: Calculating best video mode for xxxx orientation: normal
haynor666
  • retro maniac
« Reply #7 on: October 15, 2024, 03:46:48 pm »
Everything seems to be fine with version 270. I didn't have to use any special options on i3-12100F and windows 10.
