July 18, 2025, 10:23:13 pm
Nope. How about a link to the game? Maybe we can help you then.
Man that's pretty cool. It looks like the stock animation used in the series.
Actually disregard Howard, I did a little more digging and I found out that the problem is with the openGL drivers on certain machines it works and other not. Mine not. But the solution was using an older exe. Thanks anyways!
Quote from: lisowskikevin on July 12, 2016, 07:19:00 pmActually disregard Howard, I did a little more digging and I found out that the problem is with the openGL drivers on certain machines it works and other not. Mine not. But the solution was using an older exe. Thanks anyways!Bump! Experiencing the same issue, can you link to the older exe you used to fix this?Thanks
Any luck?
