Author Topic: Computer Problem/possible motherboard malfunction??? Need help.  (Read 4748 times)
Ian
  • Last login:February 27, 2026, 11:36:05 pm
« on: November 27, 2015, 04:42:02 pm »
Hey guys, I have a bit of a frustrating problem.  >:D
I have an older gaming rig computer that I have had for about 10 years now. I got a pretty nasty virus on the machine and it never really worked quite the same (duh) after that. But one thing that really got me confused was the shut down. Basically when I go to start>shutdown the computer will shutdown the operating system but the towers fans and powersupply (again duh) stay running. It's more of an annoyance at this point but I couldn't get the whole system to shut down. I have tried google searching remedies but the responses are all over the place. I just wanted to check with you fine folks since I trust you guys.
So I reinstalled the bios to the motherboard
I did a fresh install of windows 7
And I checked my power settings and still the damn thing doesn't shut off.
I guess I don't mind it too much but I usually use a "smart strip" power strip to power everything up at one time. But now that my computer tower is constantly running it really makes the strip useless.
Is this just a case of a bad motherboard? Or something that could be fixed?
Any help would be appreciated.
Phreakwars
  • Last login:December 07, 2025, 07:04:20 pm
  • Waka-Waka
    • forum.arcadecontrols.com/index.php/topic,146325.0.html
    • My Facebook Page
Re: Computer Problem/possible motherboard malfunction??? Need help.
« Reply #1 on: November 28, 2015, 05:43:07 am »
Does the CPU fan stay running as well? If you UNPLUG the tower, then plug it back in, do the fans still move? What about when you hold down the power button? Also, what motherboard is it?
Ian
« Reply #2 on: November 28, 2015, 11:48:34 am »
yes the CPU fan stays running.
If I unplug the tower and plug it back in all the fans and such turn on. The actual computer doesn't boot until I hit the tower power button.
If I hold down the power button the computer shuts down.. Just not the tower nor the fans. those stay running.
mobo is an asrock 775 dual 880pro
Ian
« Reply #3 on: November 28, 2015, 11:58:17 am »
thanks for responding btw.  :notworthy:
henrydwh
  • Last login:November 29, 2015, 01:05:38 pm
« Reply #4 on: November 29, 2015, 12:08:02 am »
You reinstalled the BIOS, but did you look at the settings? It sure sounds like a setting in the BIOS to me. Might run malwarebytes just to be safe.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:02:58 pm
« Reply #5 on: November 29, 2015, 09:21:21 am »
I will confirm that this behavior on this particular MOBO (I have 3 of them) I considered normal if you have installed Win7, Win8 , Win 10. This is the one thing I noticed once I installed WIN7, WIN8,WIn8,1,WIN10. Windows XP however works with no problem.
So your MOBO is NORMAL. I have not seen a BOIS update and probably won't bother with it anymore.
Free VGA Breakout Cable
Phreakwars
  • Waka-Waka
    • My Facebook Page
« Reply #6 on: November 29, 2015, 09:23:25 am »
Nah, wouldn't be malware. If he is unplugging it and the fans go back on when he plugs it back in, then that's a hardware issue. Possibly an add-on card? Have you tried unplugging all PCI/AGP/PCI-E etc cards, unplug EVERYTHING and anything that is connected. And then plug it back in and see if it still turns on the fans. Honestly though, it sounds like the board is bad. Best and about the only remedy is swap out the power supply with one that has an on/off switch in the back, and just flip it into the off position when not using it. And another thing to try... speaking of power supplies, is to disconnect the main leads going to the mother board, and then plug it back in and see if those fans spin without a signal from the motherboard.
Phreakwars
  • Waka-Waka
    • My Facebook Page
« Reply #7 on: November 29, 2015, 09:34:01 am »
So the board is an ASROCK 775Dual-880Pro?
Ya know... I recall having a similar problem with an ASRock board on a system I built for someone a couple years ago.. It turned out that what I needed to do, was change the jumper position on the board.
This would have been PS2_USB_PWR1 you'll find it in the upper left corner of the motherboard, or PAGE 12 of the manual shows this if your not seeing what I am talking about
http://66.226.78.22/downloadsite/Manual/775Dual-880Pro.pdf
Try switching that and see if it fixes the problem.
Thenasty
« Reply #8 on: November 29, 2015, 10:02:39 am »
I'll give a test to see if it is that ps2_usb pwr1 jumper.
Thenasty
« Reply #9 on: November 29, 2015, 10:59:38 am »
confirm that the ps2_usb pwr1 jumper did the truck (defaulted to USB). Now switch to ps2  and system do shutdown (still have the original manual but of course did not bother checking when XP was removed.)
good call, good memory.
wasted 4 minutes booting up the sytem with Win 10   :banghead:
Ian
« Reply #10 on: November 29, 2015, 03:37:17 pm »
Well this problem did start when I had windows xp. But I think it's just a mobo issue.
Ian
« Reply #11 on: November 29, 2015, 03:38:18 pm »
Yeah, I have not tried this.... I will try it out see what it does. I assume it's a bad mobo. But it would be a good test to see if it could be something else. Thanks!
Phreakwars
  • Waka-Waka
    • My Facebook Page
« Reply #12 on: November 29, 2015, 03:39:10 pm »
Try my jumper suggestion first.
Ian
« Reply #13 on: November 29, 2015, 03:39:48 pm »
Will do!
Ian
« Reply #14 on: November 29, 2015, 03:42:31 pm »
Do I just unplug the ps2 jumper? Or switch it to something else?
Phreakwars
  • Waka-Waka
    • My Facebook Page
« Reply #15 on: November 29, 2015, 03:48:06 pm »
Just switch it.
Ian
« Reply #16 on: November 29, 2015, 03:52:06 pm »
switched the jumper to the other position and It still is doing the same thing.
Thenasty
« Reply #17 on: November 29, 2015, 06:55:11 pm »
there are  3 pins. defaulted to pins 2-3 (USB). Pull up the plastic plug and put it in pins 1-2 (PS2).
Ian
« Reply #18 on: November 30, 2015, 06:33:30 pm »
Yeah thanks... I know what he was saying.. It just didn't work for me.  :dunno
I mean I am sure I could rig something so It wouldn't be a pain in the but to turn on in an arcade. Or maybe I just spring for an updated mobo.  :angry:
