Author Topic: AIR HOCKY ?  (Read 6368 times)
matt4949
AIR HOCKY ?
« on: November 23, 2014, 09:13:05 am »
So here's my idea.
Great big ol' touchscreen
Waist hi table with LED side rails
What's the largest touchcsreen?
How do I get the LEDs to fire the same as in the game?
Ideas? Thoughts?
  • Last login:Today at 07:39:54 pm
Re: AIR HOCKY ?
« Reply #1 on: November 24, 2014, 12:44:25 am »
Disclaimer: I have no idea how to write the actual code described below.
Consider using an AHK script like the one Le Chuck used in Darkade for auto-switching Tron between 4-way and 8-way depending on whether you are on a 4-way level (light cycles) or an 8-way level. (MCP)
In a nutshell AHK monitors a specific part of each video frame looking for an indication of which level you select and sets the 4-way/8-way servo stick accordingly.
For your application, you need to monitor 4 patches (red, yellow, blue, and green) of each video frame and when that color flashes brighter on the screen, have AHK trigger a relay that switches on the LED strip.
You might be able to get away with monitoring only 2 patches (red/blue and yellow/green) and doing two comparisons per patch.
Re: AIR HOCKY ?
« Reply #2 on: November 24, 2014, 07:42:39 am »
^ That should do it, the smaller the sample size the better so you don't get false positives.  I don't know how much lag there might be tho, that game is pretty fast and I don't know if the LED blinky to script to AHK to game will work out.  Give it a shot.  Have that game in windows?
lilshawn
  • Moderator
  • Last login:Yesterday at 07:34:18 pm
Re: AIR HOCKY ?
« Reply #3 on: November 24, 2014, 10:25:13 am »
ELO makes some 40 inch LCD touchscreens. IIRC they are about 3500 buck. (plus shipping) they will also make you whatever size. for a premium of course.
http://www.elotouch.com/Products/LCDs/4243L/default.asp
Re: AIR HOCKY ?
« Reply #4 on: November 24, 2014, 10:29:11 am »
lilshawn
  • Moderator
Re: AIR HOCKY ?
« Reply #5 on: November 24, 2014, 11:15:45 am »
This is the biggest one I've ever seen:
http://www.prometheanworld.com/us/english/education/products/interactive-table/activtable/
well, if y'all wanna get into a cock waving competition....
http://www.elotouch.com/Products/IDS/7001L/default.asp
no idea what their digital signage units cost, but i suppose if you have to ask, you can't afford it. 300,000 isn't anything to sneeze at when it comes to advertizing. just look at those giant roadside digital billboards.
« Last Edit: November 24, 2014, 11:17:43 am by lilshawn »
mahkeymike
  • Last login:March 19, 2026, 01:30:59 pm
Re: AIR HOCKY ?
« Reply #6 on: November 24, 2014, 11:30:56 am »
Would probably be cheaper to buy the glass overlay and find a cheap LCD tv to match. Although i cant imagine how fun it would be installing it, and making sure no dust gets inbetween.
Re: AIR HOCKY ?
« Reply #7 on: November 24, 2014, 11:46:38 am »
  • Last login:Today at 08:06:45 am
Re: AIR HOCKY ?
« Reply #8 on: January 22, 2015, 02:10:03 pm »
I had a "real" air hockey table, one sold in a sporting store, for home use.
It took about a month for everyone to grow tired of it. After gathering dust for a year I sold it.
Just saying.
Locke141
  • Never grow up.
Re: AIR HOCKY ?
« Reply #9 on: February 17, 2015, 03:00:38 am »
I would get a wii mote and a pico preceptor and build a try pod to hold them over a whit ply surface. You would need to add infored led to the padels your playing with.
http://www.uweschmidt.org/wiimote-whiteboard
Or I would just buy a Nok-Hockey.
http://www.amazon.com/Carrom-20-01-Nok-Hockey-Game-Large/dp/B00004W60Z
