Author Topic: makvision discoloration  (Read 1371 times)
aliea
  • Last login:April 23, 2014, 01:09:12 pm
« on: April 23, 2014, 01:03:44 pm »
thanks for the help in my previous thread.
im getting a new problem on my makvision 24.8. hooked up everthing going great but im gettin a purple type streak on th far right side of the tube right on the end. is something i can do to make this discoloration go away?
any suggetions would be awsome.  there no speakers or anything to that sort new it as well. just a little annoying.
thank you so much
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
Re: makvision discoloration
« Reply #1 on: April 23, 2014, 06:09:56 pm »
Try turning down the brightness and contrast.  These monitors have a reputation of being shipped with these settings turned all the way up.
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
« Reply #2 on: April 24, 2014, 11:09:10 am »
Hard to tell without seeing but it could be in need of a degauss... did yourfecently move or rotate the machine. It sounds silly but the earths magneticfields can cause that to happen if thevmachine is moved while there is still a significant charge in the tube.
You can test this by spinning the machine 90 degrees while the monitor ison to seeif the discoloration moves.
