Author Topic: GroovyMAME sound problem  (Read 7911 times)
shrunkenmaster
« on: March 10, 2014, 10:39:59 am »
I've just installed groovymame32_0151 and crt_emudriver 6.5 and am VERY impressed with my TV's picture! However, I'm having an audio problem. The sound seems to be changing pitch, or slowing down and speeding up. Can someone tell me what's causing this? I've set up GM & the driver according to these instructions:
http://forum.arcadeotaku.com/viewtopic.php?f=10&t=24216&sid=ca4c22b6885e4e8459286d191850d303
There's nothing else on the PC except TinyXP (clean format/install). The .ini file is below, let me know if you need any further info!
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     0.7
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
bios
cheat                     0
skip_gameinfo             1
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
http                      0
http_port                 8080
http_path                 web
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   arcade_15
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              0
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               1
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            0
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                0
unevenstretch             1
prescale                  1
waitvsync                 0
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.03
pincushion                0.03
scanline_alpha            1.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.3,0.0,-0.3
converge_y                0.0,0.3,-0.3
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     1.570796325
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.225
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2.0
# INPUT DEVICE OPTIONS
dual_lightgun             0
krick
  • Gotta have blue hair.
Re: GroovyMAME sound problem
« Reply #1 on: March 10, 2014, 04:45:45 pm »
If you're experiencing problems with a certain game, please create a log and post it when reporting the problem. This will provide most of the required information beforehand and will save us from asking you to post a log, which depending on your time zone may delay the answer by a couple of days.
Steps to create a log:
- Run GroovyMAME like this:
Code: [Select]
c:\mame_folder>groovymame.exe romname -v >romname.txt- Upload romname.txt as an attachment to your post. Please don't paste it inside the edit box as it makes things unreadable.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
cyb
  • Last login:December 19, 2025, 04:07:20 pm
« Reply #2 on: March 10, 2014, 10:12:54 pm »
what kind of cpu do you have? my core 2 duo system does this when it doesn't have enough horsepower to play the game at 100 percent speed.
shrunkenmaster
« Reply #3 on: March 11, 2014, 03:29:31 am »
Thanks for the replies guys. A bit more detail:
CPU is a Celeron D 2.93GHz, 1.5Gig RAM. Trying to run Power Drift (pdrift.zip). Using a UMSA scart converter to a TV.
Have tried creating a log using:
(START) (Run...) C:/MAME/GROOVYMAME.exe pdrift.zip -v pdrift.txt
and
(START) (Run...) C:/MAME/GROOVYMAME.exe pdrift -v pdrift.txt
Nothing seems to happen, save for a quick pop-up black window. Where should the log file end up anyway? I did a search for it but nothing seems to have been created. I'm not that experienced with Windows, so please allow for this!
krick
« Reply #4 on: March 11, 2014, 10:13:27 am »
and
Do this...
(START)(Run...) CMD
...to open a command prompt.  Then type...
CD c:/mame/
...to Change Directory into your MAME directory.  Then type...
GROOVYMAME.exe pdrift -v >pdrift.txt
...this will create pdrift.txt in your mame directory.
« Last Edit: March 11, 2014, 11:11:31 am by krick »
Hantarex Polo 15KHz
shrunkenmaster
« Reply #5 on: March 11, 2014, 10:42:57 am »
Hey krick, thanks for going easy!! Now I can see it's a terminal, and just as fussy as OSX...
When I enter:
I get:
ERROR: Unknown Option: pdrift.txt
I can run pdrift from this command line ok, so I'm in the correct directory using the correct spelling. Just to check, the -v is a MINUS followed by a lower case V ?
Sorry again for my PC ignorance.
krick
« Reply #6 on: March 11, 2014, 11:15:28 am »
The command line is missing a greater than character.
I corrected my last post.
Hantarex Polo 15KHz
shrunkenmaster
« Reply #7 on: March 11, 2014, 11:40:14 am »
Cool, here's the file.
Calamity
  • Moderator
  • Last login:March 24, 2026, 04:14:45 am
  • Quote me with care
« Reply #8 on: March 11, 2014, 07:16:01 pm »
Hi shrunkenmaster,
It's probably not a problem with the sound but with the game speed. While in game, press F11 to see if the speed stays at 100%. If it fluctuates, it probably means your CPU is not capable of running the game with v-sync on. Try enabling -multithreading and -triplebuffer for the particular games where you see problems.
shrunkenmaster
« Reply #9 on: March 12, 2014, 05:32:31 pm »
Hey Calamity, thanks for that, although the options suggested made no difference. I've had regular MAME 0.106 running fine on this PC with soft15Khz, but the picture quality seems so much better using GM/CRTEmu. Can you recommend a way forward for using 0.106 with CRTEmu, or something else suitable? I really need a stable build as it's for my original Power Drift cab and I desperately need to drive like a lunatic  >:D
Calamity
  • Moderator
« Reply #10 on: March 12, 2014, 06:19:47 pm »
No problem. Try ArcadeMAME: http://id4retrodev.blogspot.com.es/
(it's based on v0.106 but modified to use SwitchRes).
shrunkenmaster
« Reply #11 on: March 13, 2014, 12:09:24 pm »
Hey Calamity, tried the ArcadeMAME build and all is looking - and sounding - great!
Thanks for the input all, it's really appreciated. If you're ever in the south of England pop round for a nice cup of tea and a few games  :applaud:
ID4
  • Last login:January 29, 2025, 02:55:51 pm
    • ID4 Retrodev
« Reply #12 on: March 14, 2014, 04:00:07 am »
I'm happy that ArcadeMAME is useful for you , thanks you Calamity for remember it!
shrunkenmaster
« Reply #13 on: March 14, 2014, 10:45:23 am »
And special thanks to you, ID4!  :cheers:
ID4
    • ID4 Retrodev
« Reply #14 on: March 15, 2014, 03:27:25 am »
Do you use it standalone, or in combination with switchres via ArcadeMAME.exe wrapper?
