Author Topic: My first build! Bartop from katorlegaz's plans  (Read 3573 times)
Willlard
  • Last login:December 06, 2013, 02:40:37 am
« on: November 23, 2013, 05:05:44 pm »
Hello! I started on my first build about a week ago and I have learned a LOT so far. I was pretty much a complete noob at using tools, but after having to change the siding on my house a few weeks ago and getting some tools from that, I decided to try something I have been wanting to do for years.
I decided I would try to start out as cheap as possible so I didn't waste too much money if I ended up giving up. I haven't got a slot cutter for my router yet, Haven't got the t-molding, I don't have any real buttons or joystick, no paint or art for the sides. It may be a bit before I can afford these things, but I wanted to make sure that I could handle the job first! (I hope slot cutting the edges later wont have any problems.)
The buttons i will be using are from a cheapo wii arcade stick I got in a trade, I started soldering them to a keyboard encoder and decided it wasn't worth saving 20$ so that's another thing I need to get.
Here are some images.
Let me know what you think, tips, tricks, problems you may see.
Edit: I should also mention that I have changed the original plans a bit
« Last Edit: November 23, 2013, 05:19:45 pm by Willlard »
Slippyblade
Re: My first build! Bartop from katorlegaz's plans
« Reply #1 on: November 23, 2013, 05:57:57 pm »
Good start! Cutting the slot is definitely easier to do before assembly, but can be done afterwards.  Getting the slot centered is the biggest pain though.  Cut a slot in a piece of scrap, then flip it over.  If the slot lines back up with the cutter, BOOM - you're centered!
I see you have the 18v Ryobi set.  That's what I've got, love em.   :cheers:
Willlard
« Reply #2 on: November 23, 2013, 08:52:28 pm »
By the way, I have a small compressor. Should I use a sprayer made for that to paint this? If so, what in all will I need?
Thank you! And yes, they are great.
Slippyblade
« Reply #3 on: November 23, 2013, 08:55:49 pm »
Can't answer that one, sorry.  I've only done roller coats.  Sand.  Roller.  Sand.  Pain in the ass.
matt4949
« Reply #4 on: November 23, 2013, 09:10:09 pm »
Yeah that's what I did on Method2MyMadness. There has got to be a better way. Gonna try spraying my next one. I have been finding alot of usefull advice on painting MDF over on the SpeakerBox/Enclosure Forums.
Typefighter01
  • Last login:September 09, 2025, 12:49:12 pm
  • Back I guess...
« Reply #5 on: November 23, 2013, 09:28:16 pm »
I like the cab shape Willard. Are you cutting a marquee hole above your monitor hole and doing the traditional rear lighted plexi with art, or are you just printing art and sticking it to the wood?
Willlard
« Reply #6 on: November 23, 2013, 10:00:39 pm »
I will be putting a hole in area above the monitor for the lighting with plexi art, yes. I'm just at the point now where I need "stuff" to move on. I need to get the real buttons, I need to get paint, art,  parts for the marquee, and such so until I am able to buy that stuff, I'll be working on the front end and researching painting more.
DeathDealer
  • Last login:January 13, 2020, 01:44:29 pm
  • Hello everyone!!
« Reply #7 on: November 23, 2013, 11:26:43 pm »
what are the computer specs ?? :applaud:
Foot steps on the sand.
Willlard
« Reply #8 on: November 24, 2013, 12:02:49 am »
Nothing impressive. Just and old computer I have laying around, but its a 3Ghz, 2.99Ghz pentium D 2GB ram.
Willlard
« Reply #9 on: November 27, 2013, 02:22:18 am »
Well, just ordered the control panel hardware and the t-molding! I'm at the point where I need to paint it. I'm still not sure what I should do. If I can I want to use spray something. I really dislike using brushes and rollers.
Does anyone know a good way to spray paint this MDF? (I have a compressor so if that kinda sprayer is better then cans, let me know.) what kinda paint do I need? what kinda primer? do I even need primer?
