Author Topic: GroovyArcade Distro Vertical Orientation  (Read 3342 times)
rjpe
  • Last login:October 27, 2020, 04:52:42 pm
    • Perdigao's Arcade
« on: August 20, 2013, 08:46:08 am »
Hello,
I don't know if I'm the first getting this issue (I tried to found it on other posts, with no luck).
I installed (and reinstalled) GroovyArcade distro (64 bits) on a USB Stick and a SSD Disk (several times, for testing proposes).
I choose "Vertical" on "Monitor Orientation" when installing the distro to a disk, but the monitor orientation is always Horizontal.
I had to edit advancemenu.rc and mame.ini to get the vertical view.
Anyone noticed this?
The distro is very nice, boots quickly and runs fast! Nice Work!
Calamity
  • Moderator
  • Last login:Yesterday at 11:25:39 am
  • Quote me with care
Re: GroovyArcade Distro Vertical Orientation
« Reply #1 on: August 20, 2013, 10:48:29 am »
Thanks for reporting. Does it work however once you install it to the disk, and select the option "Monitor Orientation" again?
Steps to create a log:
rjpe
    • Perdigao's Arcade
« Reply #2 on: August 20, 2013, 12:20:26 pm »
Hi Calamity,
No it doesn't. I tried to change it several times on the installed instance, it kept horizontal.
Best,
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
« Reply #3 on: August 21, 2013, 02:05:17 pm »
hello I am having very very similar issue. however I am not using the install distro.
also I am modifying my mame.ini file for groovymame and it appears to be ignoring my requests for vertical as well.
here is my problem with more description.
http://forum.arcadecontrols.com/index.php/topic,134087.0.html
Calamity
  • Moderator
« Reply #4 on: August 21, 2013, 05:39:01 pm »
Hi arcadepcnut,
When using GroovyMAME you must leave the rotation options alone (-rotate, -ror, etc.) and use the -orientation option instead, which is GroovyMAME specific. This is because GroovyMAME manages these options internally.
So chose one of the following:
orientation horizontal
orientation vertical
orientation rotate
orientation rotate_r
orientation rotate_l
My advice is to use either "rotate_r" or "rotate_l" depending the direction you rotate your monitor.
