Author Topic: best glue for gluing mdf !  (Read 4311 times)
mebronx2000
  • Last login:December 25, 2025, 09:47:47 pm
« on: June 04, 2013, 11:55:39 am »
what is the best glue for gluing mdf !  :applaud:
Re: best glue for gluing mdf !
« Reply #1 on: June 04, 2013, 12:12:27 pm »
I've always had good luck using normal woodglue (Tightbond is a good example). Just be sure you clamp (or screw) it together while the glue sets
mebronx2000
« Reply #2 on: June 04, 2013, 02:00:04 pm »
thanks  :notworthy:
eds1275
  • Last login:June 09, 2026, 01:06:56 pm
  • Rock and Roll!
« Reply #3 on: June 17, 2013, 06:54:41 pm »
I've always used woodworker's standard yellow. I also usually clamp it down use short brad nails to pin it, and then steal my clamps back because I only have 4 good ones.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #4 on: June 18, 2013, 10:01:50 am »
Most wood glues work fine.  I've used Elmers/Titlebond/Generic HD/Lowes and they all work just fine.  The biggest thing is to make sure the surface is clean and to understand the weight/load on what you're gluing.  If you're gluing a corner make sure to use firring strips.  If you're gluing a load bearing joint make sure you back it up with either biscuits or dowlings or screws/nails.
So bottom line is you should be fine with most wood glues but make damn sure you know the load so you can build it accordingly.
spoot
  • Destroyer of electronics
« Reply #5 on: June 18, 2013, 10:28:43 am »
Pretty much any of "todays" wood glues will have the wood fail before the glue.  I recommend using a tack cloth to clean the stuff you're going to glue first though.
mebronx2000
« Reply #6 on: June 18, 2013, 08:55:10 pm »
thanks everyone for all your guys help !  :cheers: :notworthy: :applaud:
Hornet
  • Last login:August 12, 2013, 08:31:46 pm
    • Camera Restoration Materials
« Reply #7 on: June 28, 2013, 05:47:44 am »
For anyone in the UK, Gripfill makes a bond that is inseparable. The MDF is likely to de-laminate before the bond breaks.
ME- Its a bartop.
WIFE- But we don't have a bar.
ME- That's my next project! ;-)
« Reply #8 on: June 28, 2013, 07:47:05 am »
Same with Gorilla - always delaminates first.  Gorilla also expands like crazy so clamp tightly.  It's my go to product.
  • Last login:Today at 04:00:58 pm
« Reply #9 on: June 28, 2013, 08:44:32 am »
Since the directions for Gorilla Glue call for using a little water to activate it, wouldn't it cause problems with the MDF or is the exposure time so short and the amount of water used so small that it is used up by the glue?
« Reply #10 on: June 28, 2013, 09:15:22 am »
It hasn't been an issue for me.  Most of the time I use Gorilla wood glue, it's a water based PVA, with minimal expansion.  When I need a really stupid strong bond (like on some of the R2 leg pieces) I use Gorilla regular.
kahlid74
    • GamersAnon
« Reply #11 on: June 28, 2013, 10:30:09 am »
They more call for the area to be damp.  MDF can get damp, same with Plywood.  What you don't want is either getting soaked and then drying out in a dry area.  So you get the area damp, with a rag that is semi-wet.  This allows the chemical bonding to occur deeper than if it was just dry.
So no, you shouldn't see an issue with it.
