Author Topic: Update: fixed Help with an arcade monitor, picture smeared into horizontal lines  (Read 1329 times)
Aurich
  • Last login:September 12, 2021, 01:34:32 am
I have a 25" high rez (640x480) arcade monitor, fed by an ArcadeVGA. Been working great for years, monitor was bought new maybe 8 years ago.
I took the monitor out to move the cabinet today. Pretty sure I didn't break anything, no accidents or weirdness. Moved cab into garage from house, put monitor back in, hooked everything back up, and got this for a picture:
(I call the lines horizontal since they normally would be, obviously vertical on my rotated monitor.)
If I mess with the H.hold all the way I can get some vaguely clearer images, but still crazy illegible. No other control changes it. I feel like this happened when I moved it once before, but damned if I can remember how I fixed it. Anyone have any clues?
Thanks!   :cheers:
« Last Edit: April 08, 2013, 02:37:12 pm by Aurich »
dandro
  • Last login:July 20, 2014, 12:32:46 am
    • Link To project
Re: Help with an arcade monitor, picture smeared into horizontal lines
« Reply #1 on: April 08, 2013, 09:09:45 am »
almost looks like the Video Synch isn't connected.. I would check those connections (solder joints) on that. I am sure the monitor guru's will be along any minute now to give you better feedback, but I recall mine looking like that:
turned out to be the synch connection (white wire) not being solidly connected.
Aurich
« Reply #2 on: April 08, 2013, 10:44:14 am »
I can get a pic of the underside of the monitor, and while I'm there I'll see if anything obvious look disconnected. :)
Aurich
Fixed it. It was indeed a loose connection. The simple fixes are my favorite, even if you feel dumb after finding it hours later. ;)
dandro
    • Link To project
Awesome!!!! glad it all worked out! game on!  :cheers:
