Author Topic: ZSNES Help.  (Read 2490 times)
DEIVIONCRX
  • Last login:October 23, 2014, 05:18:29 pm
  • District 1
ZSNES Help.
« on: March 18, 2013, 05:58:48 pm »
I'm using MameWah and ZSNES for my Super Nintendo emulation, i cant get it to see my roms and generate a game list in MameWah for some reason.  My "roms" are .SMC file type.  Ive got Fusion Sega working with the .CMD roms and Nestopia working with .NES roms.  Is there some kinda issue with the .SMC?
"Simplify, then add lightness." - Colin Chapman
gonzo90017
Re: ZSNES Help.
« Reply #1 on: March 19, 2013, 04:09:23 pm »
Can you post the .ini file you're using for Zsnes?
DEIVIONCRX
  • District 1
Re: ZSNES Help.
« Reply #2 on: March 19, 2013, 08:02:52 pm »
I will tomorrow night.
DEIVIONCRX
  • District 1
Re: ZSNES Help.
« Reply #3 on: March 21, 2013, 09:51:44 am »
Well i figured out ZSnes, i changed the List Generator to Rom Folder and its working fine, after some messing with the emulator to get it running fullscreen.
But now i cant seem to get the Z26 Atari to generate a list.  It was set to Auto on the List Generator also, but i changed it to Rom folder and it still wont work.
gonzo90017
Re: ZSNES Help.
« Reply #4 on: March 21, 2013, 04:29:30 pm »
Set the list generator to rom_folder .
Also make sure you have the correct rom extension.
DEIVIONCRX
  • District 1
Re: ZSNES Help.
« Reply #5 on: March 28, 2013, 01:14:11 pm »
Here's my Atari.ini, i know its in the wrong folder, when i started i just threw in the folders that were already there because i didn't exactly know how to program it.  If that's the problem i can restart with a new folder that's the last thing I haven't tried.
### winuae.ini (mamewah v1.69) ###
emulator_title                            Atari
### List Generation Settings ###
rom_path                                  C:\Documents and Settings\Administrator\Desktop\mamewah_v169\config\winuae\Roms
rom_extension                             bin
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      C:\Documents and Settings\Administrator\Desktop\mamewah_v169\config\winuae\z26v3\z26.exe {nosafelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       [emurootpath]\winuae\snap
movie_preview_path
movie_artwork_no                          1
enable_fuzzy_search                       1
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              1
DEIVIONCRX
  • District 1
Re: ZSNES Help.
« Reply #6 on: March 28, 2013, 01:15:43 pm »
I've also run across another issue with my Mame roms.  Roms that worked before no longer work.  When i first got the thing working Tempest worked great.  I haven't been able to get Tempest to work in a few weeks.  Last week i played Tron for like 30mins, yesterday i want to play Tron it wont work either.  Any ideas, i opened Mame32UI again and re-audited all games but nothing changed.
I'm also running a 2007 build of Mame32, along with a 2011 build of Mame32UI and i tried Tempest and Tron on both build neither works.
gonzo90017
Re: ZSNES Help.
« Reply #7 on: March 29, 2013, 07:00:11 pm »
Every emulator has a different command line. You always need to find out what it is before adding it to mamewah. Here is a brief tutorial on how to get WinUae running in mamewah.
Not sure what your problem is with mame? Are you sure you have set the correct rom folder in mame? It's clearly not anything to do with Mamewah since you seem to be having issues running the games outside of it. I would try running the latest version and redownloading the games that are giving you trouble.
