Author Topic: Trimming sideart  (Read 2039 times)
wcndave
  • Last login:June 10, 2021, 03:37:36 am
Trimming sideart
« on: October 04, 2012, 01:55:07 pm »
I am looking at getting some art done from gameongrafix or a UK based firm if I can find one.
i assume it comes rectangular, so how does one trim the edges to match the shape of the cab?
i can imagine using scissors could leave ragged edges, and a knife marks in the laminate.
any clues?
Dave
yaksplat
    • Random Projects
Re: Trimming sideart
« Reply #1 on: October 04, 2012, 02:17:29 pm »
Just glide a sharp blade around the perimiter of the cab once the vinyl is on.  It'll cut through it like butter.
http://yaksplat.wordpress.com
« Reply #2 on: October 04, 2012, 02:52:56 pm »
Two different techniques I've used.
Apply art, trim it to a half inch overhang and wrap the excess along the edge and into the T-molding channel so that it gets held down by the T-molding once you install it.  Pros:  no corner peel.  Cons: Ginourmous PITA
Apply with T-molding already installed and insert a new blade between the T-molding and the side panel.  Gently pull your way along the cabinet for a nice neat trimmed edge. Pros: Easy-peasy.  Cons: Peeling can be an issue depending on print source (though I've never run into it)
wcndave
« Reply #3 on: October 04, 2012, 03:48:54 pm »
Hey that helps, but is the t moulding not glued on so there is no gap?
  • Last login:Today at 01:44:44 pm
« Reply #4 on: October 04, 2012, 05:42:56 pm »
Check out 14 minutes into the video from this post from Rikitiki's Side Art Install 101 thread for his advice on the subject.
t3design
  • Last login:Yesterday at 07:40:57 am
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
Trimming sideart
« Reply #5 on: October 04, 2012, 06:34:18 pm »
I did the thin blade between cab and tmolding and it worked like a charm. Be sure to keep the blade pressure against the cabinet.
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
wcndave
« Reply #6 on: October 05, 2012, 04:01:27 am »
Thaks everybody
