Author Topic: Word Writer for C64  (Read 3236 times)
Word Writer for C64
« on: May 14, 2012, 10:50:29 am »
So I've got Word Writer for the C64, but for the life of me I can't figure out how to load a saved file from a floppy.
Any of you old farts remember how?
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
Re: Word Writer for C64
« Reply #1 on: May 14, 2012, 11:12:46 am »
F2, you'll hold shift and F1.
lanman31337
« Reply #2 on: May 14, 2012, 11:18:02 am »
LOL guess what I found?  Instruction manual for WW5.
http://project64.c64.org/misc/wordw510.zip
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #3 on: May 14, 2012, 02:09:16 pm »
Hey get out of the dark ages and use vi for your C64 word processing needs.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 10:57:35 pm
« Reply #4 on: May 14, 2012, 03:29:01 pm »
use Speedscript nice and easy  :P
Free VGA Breakout Cable
« Reply #5 on: May 14, 2012, 03:36:21 pm »
I'll have to see if I have that cheat sheet thing that you taped on the keyboard that told you what all the word writer special function keys did.
I don't even know what would possess you to dive into word writer these days. I thought using WW is considered a form or torture these days.  :dizzy:
« Reply #6 on: May 14, 2012, 05:55:49 pm »
I have disk with a document on it, and I want to see what's there.
The filename, according to LOAD"$",8 is:
"W/W DATA03/28/92"
What do I use as the filename to load?  I've tried all combinations of the above I can think of.
Ed_McCarron
« Reply #7 on: May 14, 2012, 07:44:13 pm »
God, I hated typing that in.  Even with the checksum program running.
Thenasty
« Reply #8 on: May 14, 2012, 09:18:19 pm »
try
load "*",8,1
or
load "W/W DATA03/28/92" ,8,1   but this looks like DATA not the actual program. It prob ended with SEQ not PRG (extension way to the right colum)
then
RUN
« Last Edit: May 14, 2012, 09:22:33 pm by Thenasty »
Thenasty
« Reply #9 on: May 14, 2012, 09:24:10 pm »
you can type
load "$",8,1
then type
LIST
see which is the PRG for the program
then type
load "whatever its called",8,1
run
lanman31337
« Reply #10 on: May 15, 2012, 08:11:53 am »
Since there's just the prg on there, load"*",8,1 will work just fine for you.  You may have to type run as well after.
