Author Topic: MDF Question  (Read 1989 times)
bgandy
  • Last login:March 09, 2012, 07:30:57 am
MDF Question
« on: February 12, 2012, 11:46:47 am »
I am currently planning my first cabinet.  I was planning to use MDF, but I am uncertain if I will be able to use T-Molding with MDF.  Is it possible or should I use hardwood?
Sorry for the simple question.  I worked in a cabinet shop for years, but I only finished cabinets.....never built them.
Re: MDF Question
« Reply #1 on: February 12, 2012, 12:30:02 pm »
MDF is very T-molding friendly so no issue there.  I like MDF for the smooth no grain finish and it cuts very easily.  Watch out for the dust tho.
bgandy
Re: MDF Question
« Reply #2 on: February 12, 2012, 12:58:25 pm »
Thanks.  I am planning on painting the cabinet for now so I figured MDF was the right choice because I want a smooth finish.
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: MDF Question
« Reply #3 on: February 12, 2012, 11:16:34 pm »
Are you asking about plywood or actual hardwood?  If we're talking a true hardwood I would say no.  If you think MDF is heavy a cab made out of "hardwood" would be super heavy and would really do a number on your router bits.
MDF works great for T-Molding and painting.  It's a little heavy but build it so either the internals can be removed for transportation or with good grips and you'll be fine.
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
Re: MDF Question
« Reply #4 on: February 13, 2012, 12:47:52 pm »
If it is in the budget, then MDO is > than MDF.  Regular plywood with a resin paper coating that takes paint extremely well.
