Author Topic: VGA to Arcade monitor, SYNC question.  (Read 2164 times)
dave197878
  • Last login:May 03, 2012, 12:30:19 pm
« on: December 11, 2011, 03:37:02 pm »
I Have an arcade cabinet with a working game board and WG K7000 -25" monitor.
Currently the video wires hooked up to the game board are:
R, G, B,  GND,  -HOR SYNC
R -----------------
G ----------------
B-----------------
GND   --------------
+ VERT SYNC  (Empty)
+ HOR SYNC   (Empty)
GRND             (Empty)
 - VERT SYNC  (Empty)
 - HOR SYNC    ------------
I have the ultimarc video amp which has "OUTPUT" terminals with  R,B,G, SYNC, GND (and one empty terminal).
The R,G,B, GND are no brainers. I just want to confirm that the
- VERT SYNC - HOR SYNC  connect  together into the SYNC out the ultimarc video amp? +V+H are not used.
I found this info here:
http://www.instructables.com/id/MAME-Cabinet-in-4-key-steps/step2/VGA-to-the-Arcade-Monitor-hookup/
Just want to confirm it's correct for my monitor. Thanks.
« Last Edit: December 11, 2011, 03:44:41 pm by dave197878 »
ahofle
    • Arcade Ambience Project
Re: VGA to Arcade monitor, SYNC question.
« Reply #1 on: December 12, 2011, 12:37:58 pm »
If you only have one sync input it's probably composite sync and you simply tie V and H sync together in the VGA cable.
mrazy1
  • Last login:December 31, 2011, 05:32:46 pm
« Reply #2 on: December 13, 2011, 12:19:50 am »
Seems like you got the right card and right Idea. GO for it. basically the monitor divides the sync at a transistor on the monitor board. but like the Website said youhave to have a 15 khz signal at all time and that card you have is native output is 15khz.
Thanks Michael
dave197878
« Reply #3 on: December 13, 2011, 11:48:04 am »
K will give it a shot. The ultimarc guy said to hook it up exactly the way it's hooked up now to the Org game board... R, G, B,  GND,  -HOR SYNC Will give it a shot.
