Author Topic: IPAC2 Problem  (Read 3128 times)
dugg8
  • Last login:February 01, 2012, 04:51:00 pm
IPAC2 Problem
« on: August 14, 2011, 09:49:09 pm »
Hey guys,
I just finished my scratch build this weekend and I'm currently in the process of working all the bugs out on the software side. For a keycoder I'm using the Ipac2 and running a PS2 cable into a PCI card that has both USB & PS2 ports. Now I have it all setup and everything works great BUT when I go to do a move that requires pressing 3 buttons simultaneously (ie -  Zangief's spinning lariat) it only registers maybe 10% of the time. Anyone run into this problem?
spoot
  • Destroyer of electronics
Re: IPAC2 Problem
« Reply #1 on: August 15, 2011, 11:58:16 am »
Perhaps the pci card doesn't buffer properly?  Try in notebook or other text editor......many keys at once and see if the keys show up properly?
dugg8
Re: IPAC2 Problem
« Reply #2 on: August 15, 2011, 03:07:48 pm »
Good idea. I'll try that out.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:26:12 pm
Re: IPAC2 Problem
« Reply #3 on: August 15, 2011, 07:49:44 pm »
your MOBO don't have PS2/USB ports ?
Free VGA Breakout Cable
dugg8
Re: IPAC2 Problem
« Reply #4 on: August 15, 2011, 11:26:38 pm »
The motherboard has USB ports only
Hoopz
  • Intellivision Rocks!
Re: IPAC2 Problem
« Reply #5 on: August 16, 2011, 08:03:43 am »
I assume then that you only have the PS/2 cable?  The easiest solution is get the USB cable.  You can order it from Divemaster127.  He carries the Ultimarc line of products in the U.S.
MonMotha
Re: IPAC2 Problem
« Reply #6 on: August 16, 2011, 07:07:36 pm »
I'd wager that the PS/2 ports on this PCI card are actually just a crappy PS/2 to USB converter dropped on the board and hooked to what would otherwise be another USB port given that it has USB already, and putting "real" PS/2 ports that don't require extra drivers on PCI is essentially impossible.  Most of these can't handle more than 6 button presses, and some handle even fewer.  I know Ultimarc specifically recommends against the use of such converters, especially since the IPAC can be a native USB device.
Re: IPAC2 Problem
« Reply #7 on: August 17, 2011, 09:05:26 am »
Hey guys,
YES! I just dealt with this on the MKII machine I'm building. In my case, the key presses registered, but would only stay pressed for 1 second. So, doing a charge (holding a button down) wouldn't work.
Hoopz is exactly right. It had been a while since I bought a machine and I thought the ipac used for USB was a different style ipac so I ordered an entire ipac thinking there were USB ipacs and PS2 ipacs. When it showed up and I realized it used a PS2 to USB cable. lol. So, I have an extra ipac.
Hoopz
Re: IPAC2 Problem
« Reply #8 on: August 17, 2011, 09:09:11 am »
Betcha a dollar that PBJ posts and offers you $5 for the I-Pac...   ;D
Re: IPAC2 Problem
« Reply #9 on: August 17, 2011, 01:18:45 pm »
Damn, that sucks. I was totally going to sell it to him. Off to the trash.
