Author Topic: Mamewah and Bluetooth  (Read 1113 times)
beatter
  • Last login:January 19, 2012, 12:47:48 pm
  • Professional Noob
    • Jaswin
« on: August 07, 2011, 12:59:44 pm »
I'm trying to setup my wiimote to work as a lightgun, and possibly steering wheel. I got the wiimote setup and connected with bluesoleil. I got WiinRemote to work as a mouse.
I then started up mamewah to see if it would magically work perfectly the first time around with no luck. The problem was once I started mamewah it was acting like the up key was constantly being pressed. I wasn't pressing any buttons or moving my joysticks or anything, my only option was to restart.
I discovered that the problem occurs whenever I turn the bluetooth on.
Any suggestions? I'm running Bluesoleil 6.something? with an old Motorola adapter.
Edit: I think I have discovered the root of the problem. Windows is considering the wiimote to be joystick #1 and therefore the controller for mamewah. I guess I need to somehow disable the joystick features of the wiimote so I can just use it like a mouse. Also, in mame it's a similar issue and it does not recognize the wiimote as a mouse.
« Last Edit: August 07, 2011, 03:45:20 pm by beatter »
My MAME Cabinet - Very First...Ever!
gonzo90017
Re: Mamewah and Bluetooth
« Reply #1 on: August 07, 2011, 08:43:11 pm »
Have you tried disabling the joystick in Mamewah? Go to Mamewah/config and open Mamewah.cfg go to
Code: [Select]
### SETTINGS ###
# 0 or 1 (off / on)
keyboard 1
mouse 0
joystick 1
and set joystick to 0
Code: [Select]
joystick 0
