Author Topic: P1,P2, exit, pause, how'd u configure in Mame. Noobie  (Read 5274 times)
SirStupidQuestion
  • Last login:June 04, 2012, 01:34:47 pm
« on: August 05, 2011, 04:12:47 pm »
I have a two player bartop cp. 6 buttons each player and a player 1 start and player 2 start buttons, a pause button and an exit button. Does anyone have a similar setup and have a button configuration they like in Mame?
Currently I have the p1 and p2 buttons acting as stated, p1 start and p2 start.  Exit is exit and pause is pause.
However I am using One of each players buttons as insert coin but that sucks as if it's a 6 button game your kicking and inserting coins.
I don't want to configure the p1 and p2 starts to insert coin cause my nieces and nephews play by themselves frequently. I don't want to change the exit and pause cause the artwork is done, and I don't really want to have pause and p1 insert a coin (shift)
Anyone have what they think is the perfect setup with a p1,p2,exit,pause for Mame?
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 09:55:40 am
Re: P1,P2, exit, pause, how'd u configure in Mame. Noobie
« Reply #1 on: August 05, 2011, 04:44:00 pm »
use P1 button and P1 start to insert coin. Do the same for P2.
in MAME config set COIN 1 P1 button AND P1 Start
ie:
P1 Button = E
P1 Start = 1
set
P1 Coin 1 (instead of 5) E AND 1
so when you need to insert coin(s), press P1 Button (holding it down) and START.
Free VGA Breakout Cable
djm858
  • Last login:March 27, 2015, 09:05:10 pm
« Reply #2 on: August 05, 2011, 05:13:30 pm »
For the cab we had at my college dorm, we had the buttons for P1 & P2 Start and to insert coins we held down P1 and moved the joystick left or right to add a credit (Could hold down P2 Start and move joystick for P2 credit).  Your little nephews and nieces may have trouble remembering it, but I thought it was a nice method of adding credits without ever accidentally adding any during play.
EDIT: Sorry, I guess that's essentially the same thing you're trying to avoid (SHIFT)
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #3 on: August 05, 2011, 05:17:16 pm »
Add 2 small 18mm sanwa buttons for coins next to the start buttons.  They are pretty small, take next to no space
« Reply #4 on: August 05, 2011, 05:40:10 pm »
Easiest thing for your nieces and nephews would be to have P1 & P2 Start mapped to insert a coin and also start the game. Instead of kicking and inserting a coin at the same time with your current set up; when you press start the first time it will insert a coin, when you press it a second time it will start the game and insert the next coin simultaneously.
« Last Edit: August 05, 2011, 05:41:53 pm by Nephasth »
