Author Topic: MAME 0.142 is out  (Read 7818 times)
ntk
  • Last login:June 06, 2011, 12:09:59 pm
MAME 0.142 is out
« on: April 03, 2011, 10:30:56 am »
robertsig
  • Last login:April 14, 2025, 12:28:52 pm
Re: MAME 0.142 is out
« Reply #1 on: April 05, 2011, 06:26:33 am »
So did they fix or break any classic games with this one?
wol-nz
« Reply #2 on: April 10, 2011, 10:54:21 pm »
How do you tell if the next or latest version will break my ROMS.
I've got two machines:
One vertical cab and uses the 0.115MAME version with highscore diff patched (not changing as it works)
One horizontal cab and uses 0.81MAME version (I just can't get any other new MAME version to play my street fighter roms)
Is there an audit utility i'm missing? I don't suppose i'm missing much anyway by getting the newest version?
« Last Edit: April 10, 2011, 11:03:45 pm by wolwol »
  • Last login:June 19, 2026, 12:33:17 am
« Reply #3 on: April 12, 2011, 08:43:42 am »
:laugh2:
Bu buh buh but it's about preserving old pcbs or some such nonsense.
Who cares?  Final burn alpha is the new hotness
I sincerely hope you are kidding.  FBA only supports about 700 games... Games that have been in MAME and have been working PERFECTLY for YEARS.  Yes FBA the emulator in which they literally look at the drivers from mame and use them to add new games, is superior to the emulator that it swipes it's code from.  That's the silliest thing I've ever heard.  Next you'll tell me that KRAZY KONG is better than Donkey Kong.
Also it's an irrelevant point because classics just don't "break" in MAME.  They don't, it's a myth.  Been using mame almost from the start and there might have been 3 or 4 times in it's history when some games that had stable drivers "broke".  It was usually due to a bug after some major core re-write and the games in question were fixed within a "u" build.  When you are dealing with an emulator that supports over 5,000 games, that sort of thing tends to happen once in a blue moon.
VanillaGorilla
  • Coin detected in pocket
« Reply #4 on: April 12, 2011, 11:22:28 am »
Relax - it's only PinballJim..
Hoopz
  • Last login:June 09, 2026, 10:42:21 am
  • Intellivision Rocks!
« Reply #5 on: April 12, 2011, 11:56:08 am »
Relax, it's only Howard.   ;)
jamesjones626
  • Last login:March 08, 2025, 01:58:57 am
« Reply #6 on: April 12, 2011, 01:39:07 pm »
o ya incase you didnt know .142 will eat up about 1.2 gigs of ram when using it.
jimmy2x2x
« Reply #7 on: April 12, 2011, 02:25:00 pm »
Errr, no it doesn't, MameUI is a different matter.
"2011.04.04 Warning: MameUI .142 is being released but it is still taking 1.2GB in memory when loaded, this is compared to 215MB of .141.
The x86 version may crash out if used w/out sufficient resources.  The DEVs continue to investigate."
« Reply #8 on: April 12, 2011, 02:27:06 pm »
Is this the driverman update edition?  :laugh2:
  • Last login:May 19, 2026, 11:21:47 am
« Reply #9 on: April 12, 2011, 03:07:00 pm »
 I sure hope so!  >:D
jamesjones626
« Reply #10 on: April 12, 2011, 05:16:38 pm »
i stand corrected, i never really use mame, just mameui. im a noob like that    :)
robertsig
« Reply #11 on: April 12, 2011, 06:15:26 pm »
I'm staying with my modified 0.141u3 right now.  Works great.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #12 on: April 13, 2011, 08:45:03 am »
I also still at mame around .110 and no need to update (games I want works, but Donkey Kong is slow, due sound). Mame big issue is also clutter and its being using more ram also need more power.
So mame is not allready the best emulator. FinalBurn is a good emulator too, and is pretty fast.
But all in all, I guess both is right this time.
ids
  • Fighter Captured
« Reply #13 on: April 13, 2011, 08:56:40 am »
Support for SW Yoke is still broken  :(  I get erratic movement.  Works fine in 106, not 138 and beyond, not sure about other versions.
ids
  • Fighter Captured
« Reply #14 on: April 13, 2011, 09:43:02 am »
It's not broken, it's more accurate.  Enjoy your mah jong.
At least they have their priorities straight  ;D - maybe one day I'll look at the code and fix it myself....maybe
For now, my FE is configured to launch 106 for starwars; hacky, but it works
That reminds me, I need to filter out all non-mahjong games in FE, who needs all that retro-gaming ---steaming pile of meadow muffin--- anyway, it's all too accurate  :laugh2:
Haze
    • MAME Development Blog
« Reply #15 on: April 13, 2011, 10:23:51 am »
The problem is MAMEUI has no devs who can program, basically it's only the guy who updates the website left, they've been leaning on MESSDev to fix their bugs for the past few years but MESSDev aren't really interested in doing this.
Unless somebody pops up and fixes the issues I have a feeling you won't be seeing any new (stable) MAMEUI builds from this point forward.
robertsig
« Reply #16 on: April 13, 2011, 11:19:35 am »
So all this being said, what is the latest stable version of MAME + MAMEUI that is best for the classic games?  Maybe I should just stop upgrading now.
Haze
« Reply #17 on: April 13, 2011, 02:39:43 pm »
It's a matter of taste (and your system specs etc.), but the latest command line version should always be fine.
If you don't like DK discrete sounds, use an older version
If your PC spec is awful, use a much older version.
If you have specific hardware which doesn't seem to respond well with current versions, try other versions.
If you're running a modern OS, don't try and run old versions, they'll probably explode in your face ;-)
Bugs will creep in, and be fixed all the time, there is no definitive, 'perfect' version, not even the old ones, they have their own bugs, own incompatibilities etc.
It's really just a case of 'try things, and see what works best for you'  Start with the newest, work back.
clutch
  • Last login:February 06, 2014, 02:26:56 pm
« Reply #18 on: April 13, 2011, 03:00:32 pm »
Or use a front end that will let you run different versions for different games. :)
Time Pilot
  • Last login:January 25, 2015, 10:25:30 pm
« Reply #19 on: April 20, 2011, 08:07:48 pm »
To that end, has anyone ever compiled a table/mapping of game vs. best MAME version to play it in? Seems like a PITA, and most many (most?) may not matter, but would be excellent to have...
-TP
Haze
« Reply #20 on: April 21, 2011, 12:43:18 pm »
-TP
Nobody can, the reasons people have for picking one version over another are more often than not subjective.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #21 on: April 21, 2011, 10:57:15 pm »
A neat option, would be to toggle sample use on/off.
Nor do roms, but...paraphrasing RB....the proles just want it to work, and gross language comes easily in such case.
-Banned-
