Author Topic: MAME running slow?  (Read 4977 times)
quadrider1
  • Last login:July 14, 2012, 11:41:42 am
MAME running slow?
« on: March 24, 2011, 12:28:23 am »
so i got a computer with 2.8ghz, 504MB ram, and installed this video card for a guy but mame is just running to slow. Im using version .139 and it has worked on every other computer i have used except for this one. Could it be the video card that i installed? It wont initialize direct 3D could that be why? any thoughts
Just looked at video card, ATI radeon 7500 64 MB PCI, Could this be the problem lol seems like a very little amount of ram
« Last Edit: March 24, 2011, 12:31:39 am by quadrider1 »
bkenobi
Re: MAME running slow?
« Reply #1 on: March 24, 2011, 01:33:17 am »
That system spec look ok to me, but if things aren't set up correctly driver-wise, then it will run in suck mode for sure!  I've had a computer set up with the wrong video driver in the past take minutes to boot only to boot in seconds (as was appropriate for that machine) with the video driver correctly set up.
mytymaus007
« Reply #2 on: March 24, 2011, 08:33:44 am »
Do a clean install of windows
isucamper
    • my project arcade blog
« Reply #3 on: March 24, 2011, 09:25:10 am »
Which games are you trying to run?  Some games just run slow. You could also play with the directx/d3d setting to see if one runs faster than the other on your setup.
THE SYSTEM          Popeye
ark_ader
  • I glow in the dark.
« Reply #4 on: March 24, 2011, 03:30:53 pm »
Is one of those games Dkong, by chance?  :lol
quadrider1
« Reply #5 on: March 25, 2011, 05:40:22 pm »
Im just tried the onboard video card and go the same slow speed on dk and ms pacman, upgraded to 1gb memory. But this time i got the "unable to initializ direct3d" and it wouldnt load so i put d3d to version 8 and it loads but slow still. ddraw doesnt even work. Im lost since i always use these computers.
ark_ader
« Reply #6 on: March 27, 2011, 04:48:22 pm »
Just reinstall the Radeon Drivers.
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« Reply #7 on: March 28, 2011, 11:40:08 pm »
i suggest you use a older version maybe pre 117, i suggest 106. I wouldn't spend time using the newer versions
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
