Author Topic: Could I use this as a 2nd monitor?  (Read 2602 times)
shrunkenmaster
« on: July 20, 2010, 12:40:52 pm »
I'm thinking of adding a 2nd monitor to display some graphics as part of a control panel and was thinking about the type described below. So, a few questions:
Could you connect this from the PC's VGA port?
Could I run a program (ie. a Flash SWF) and output this to the 2nd monitor?
Thanks in advance....
# 100% brand new,High quality
# Screen Size:3.5 inch(4:3)
# Resolution:640(H) x RGB x 480(V)
# Model: PAL/NTSC (Automatic throw-over)
# Power Supply:DC 12V
# Visible Area:72 x 53.56
# Power Consumption:0.53W
# 2-channel video input:V1/V2 auto switching(V1 display first)
# Note:please Connect the Rearview camera's power cable with Reversing lamp,and connect camera's video cable with LCD's yellow cable(Video V1),then the LCD will show Camera's video when you are Reversing,and stop playing movie(auto switching)
# Display blue screen on no signal.
# Dimensions:107mm(L) x 80mm(W) x 15mm(H)
shrunkenmaster
Re: Could I use this as a 2nd monitor?
« Reply #1 on: July 28, 2010, 11:06:38 am »
Bumpity bump
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #2 on: July 28, 2010, 11:14:32 am »
It looks like it only accepts composite input (the yellow plug). Your video card would have to output that. Most cards now will let you assign that as a secondary output. To use VGA you'd need some sort of converter box.
shrunkenmaster
« Reply #3 on: July 28, 2010, 12:10:48 pm »
Thanks cotmm86030,
I was also thinking about using a DVD player connected to one of these. I take it I'd need a player with composite too.
« Reply #4 on: July 28, 2010, 12:23:58 pm »
How much and where do you get them.
I've been looking at the MIMO USB monitors but they're a bit $$$.
But they can also do touchscreen, which could be slick...
shrunkenmaster
